Old 11-03-2020, 08:47 PM   #1
Peanut74
I HATE rust!!
I thought I was done with all my rust work. That is until I got to the inner fender wells. Both of them had a bad rust that needed to be fixed. Thought about just buying report's but after reading comments on them I decided to repair them. Luckily I had one that I could use for patch panels.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 11-03-2020, 10:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: I HATE rust!!
Lookin' good!
I have quite a few of them that need a little work. I keep putting it off. I lost the patches I had made for one of them for a while but I found them the other day. I better get them welded in before I lose them again....
LockDoc
Leon
Old 11-03-2020, 10:29 PM   #3
Peanut74
Re: I HATE rust!!
Thanks LockDoc, I am hoping to get it all welded up tomorrow.
What do put on your inner fender well once you have it welded up and ground down? For the wheel side I was thinking POR15 then a light coat of bed liner. For the engine side single stage to match the truck.
Old 11-03-2020, 11:34 PM   #4
LockDoc
LockDoc's Avatar
Re: I HATE rust!!
For a filler on anything like that I always use a product called "Metal to Metal" It is an aluminized filler and won't absorb moisture like regular filler, then a coat of epoxy primer, then undercoating. Top side same thing but with the paint.
LockDoc
Leon
Old 11-06-2020, 10:26 PM   #5
Peanut74
Re: I HATE rust!!
Well I got the inner fender wells painted today as well and the radiator core support. I fixed the major rust areas and put rust converter on the other pitted areas. Painted them with epoxy primer, 2k primer then paint. Hopefully tomorrow I can get the bed liner on the inside of the fender wells over the epoxy primer.
