11-04-2020, 04:42 PM | #1 |
bagged c10 headers exhaust questions
Now that I have a fresh 350 and a fresh 700r4, it's time to do the exhaust.
I changed the front crossmember to one that would let the tucked exhaust clear, now i have to decide what headers to get. I can't find a shop in Austin Tx that will just do the whole thing. They want me to supply the headers and rear crossmember. Do you guys like the short headers that just point straight down or the type that swoop back? Any troubles hitting the 700r4 shift linkage? suggestions on which headers (to hang the exhaust high) to order is much appreciated. Not looking to go cheap or break the bank. This is just a weekend driver. thinking of this- https://www.jegs.com/i/JEGS/555/3005...3L+%2F+327+%29 or https://www.ebay.com/itm/Truck-Heade...8AAOSwCRVfZEq8 thanks steve 1968c10 350 700r4 bagged Last edited by steeeeeve; 11-04-2020 at 05:14 PM. |
11-05-2020, 04:55 PM | #2 |
Re: bagged c10 headers exhaust questions
Can't speak to small blocks, but I used Chevelle Hedders on my big block. I did have to modify the shift linkage on the TH400 and get a tubular trans crossmember, but it tucks up nicely. I used a Pypes stainless kit and modified it to fit.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-05-2020, 06:21 PM | #3 |
https://www.summitracing.com/parts/hed-69010
ordered these hedmans and going to hopefully make them work. |
11-06-2020, 02:12 PM | #4 |
With any header, there might be tweeks to the shift linkage required. Those 3/4 length headers should work well for your exhaust placement needs & keep things above the lip on the bottom of the frame rail.
