![]() Join Date: Jul 2015
Clutch linkage for the 4-speed trans
Anyone running the standard linkage? I have a 63 C20, 292, 4-speed. The clutch fork has two positions for the rod coming from the pedal, and it looks like it could fall out of place.
I was thinking of using some safety wire to make sure I don't lose any parts. Anyone else done this?
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 11-05-2020 at 03:10 PM. |
Re: Clutch linkage for the 4-speed trans
you need a clutch fork return spring that goes from the tip to the frame.
1961 chevy K10 my build is------------61K10 build |
Pics?
1963 C20, small window, long bed 292, 4-speed |
![]() Join Date: Feb 2011
MusicMan70 1961 GMC Suburban Last edited by MusicMan70; 11-05-2020 at 04:07 PM. |
I’m wondering how long that return spring is.
Likely about a foot long.
🤔 Really, a foot long? That’s a long spring.
Look in post #4 in that link.
It’s not all coils. |
Yeah, see what you mean.
Hey guys, I’m going through the “where in the hell does the clutch return spring go” also. I don’t think Bubba had mine hooked up correctly. I have a larger diameter shorter in length spring and no other spring. When I purchased a new clutch return spring for a 1966 c10 I only saw the larger diameter shorter length spring. I guess I will install the spring that I bought between the clutch fork arm and the linkage plate that holds the other end of the clutch adjustment rod.
peace Bud ![]() 1966 C10 4X4 1962 Impala Sport Coupe 1974 Corvette Coupe 1987 Suburban |
#12 | |
Moderator
![]() ![]() Join Date: Aug 2011
#13 |
Thanks. Ordered one. Is the one of which I’m referring to for the clutch pedal itself?
#14 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#15 |
My clutch is set up with the push rod on the outboard hole. I figured it would give me more leverage that way for my leg. Did 6 cylinders use the inboard hole and wouldn't that decrease leverage at the pedal?
#16 |
there is a notch or hole forward on the frame where the spring hooks into.
anybody know why there is two notches on the throw-out bearing fork?
#17 |
![]() ![]() ![]() Join Date: Jan 2018
I had half of that same spring above left hanging on the frame of my 63 when I got it. Of course, I took it off 6 years ago and don't remember where it was hooked into
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
