11-05-2020, 10:59 PM | #1 |
72 c10 a/c wiring harness
Can anyone tell me where the factory a/c harness plugs into the fuse panel? I have a new m&h harness. Thanks
11-05-2020, 11:56 PM | #2 |
Re: 72 c10 a/c wiring harness
11-06-2020, 12:02 AM | #3 |
There's a pretty good discussion about factory A/C wiring and how it works on this thread.. Also, someone posted a nice factory A/C schematic..
http://67-72chevytrucks.com/vboard/s...d.php?t=813743 |
11-06-2020, 12:28 AM | #4 |
My harness has a pink 12ga also at the fuse panel, where does this one go? Thanks
11-06-2020, 05:40 PM | #5 | |
Typing out a description of where each wire in a harness connects can be a lengthy and complicated process.. I suggest you get a color wiring diagram to aid you in this project.. Go to the electrical forum and download a diagram.. |
11-06-2020, 06:27 PM | #6 |
I'm talking about the pink wire in the AC harness. I just contacted m&h the manufacturer and they told me that it sounds like I have a 1971 harness that included the anti dieseling relay as part of the AC harness only found in 1971. My truck is a 1972. Thanks for the help fellas.
11-06-2020, 06:55 PM | #7 |
If I recall correctly the 72 AC harness has the TCS (transmission controlled spark) wiring with it.
Found a thread with the TCS wiring https://67-72chevytrucks.com/vboard/...&highlight=TCS It does use a pink wire
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 11-06-2020 at 07:01 PM. |
