Old 11-06-2020, 09:08 AM   #1
kens65fb
When I apply the brakes my idle drops too much
My 350 SBC (mild cam, turbo 400) idles fine, at about 900 RPM.
When I apply the power brakes in PARK, the idle drops about 200 RPM.
When I shift the automatic trans into, DRIVE, or REVERSE, my idle drops an additional 150 RPM, or so, which I believe is probably normal.
It is at this point, the idle, is down to about 550 RPM, and the idle becomes rough, barely running, but does not stall.
I know that is not electrical, as I have completely removed the ALL wiring from the vehicle.
The only electrical wiring left is the ignition switch, with 3 wires.
Any thoughts
kens65fb is offline   Reply With Quote
Old 11-06-2020, 09:26 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: When I apply the brakes my idle drops too much
Your booster is likely leaking somewhere.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-06-2020, 01:22 PM   #3
kens65fb
Anybody else ??
What is the best way to test the booster?
Old 11-06-2020, 02:33 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Mity-vac or plug it.
Old 11-06-2020, 02:33 PM   #5
jchav62
1962 C-10
jchav62's Avatar
I'm assuming you have a vacuum power brake booster. Must have a vacuum leak.. either in the booster itself or possibly in the vac line or connection? Disconnect the vacuum line, plug it and see if it makes a difference in the idle.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-06-2020, 04:20 PM   #6
forestb
forestb's Avatar
I was also thinking vacuum leak. But could it be the torque converter?
forestb is offline   Reply With Quote
Old 11-06-2020, 04:24 PM   #7
straight6chevyguy
straight6chevyguy's Avatar
Like the others have said, power brake booster.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 11-07-2020, 08:29 AM   #8
kens65fb
O.K. s the latest.
I disconnected the vacuum line to the booster and plugged it, idle remained at 900 RPM.
When I applied the brakes, NO decrease in RPM, so, I'm guessing that the booster is a problem, but when I shifted into DRIVE, the RPM dropped to about 575 RPM. about where it was previously, with the booster connected.
I'm at a loss, someone mentioned torque converter, can that affect idle?
Old 11-07-2020, 08:50 AM   #9
The Rocknrod
Moderator
How are you setting idle? What screws are you using, the idle mixture at the carb base or the single one at the throttle?
Old 11-07-2020, 09:00 AM   #10
kens65fb
It is a brand new Edelbrock 1906 carb with an electric choke, I am NOT a seasoned mechanic, but I adjusted the (2) screws at the base of the carb, with a vacuum gauge to get the best vacuum.
The screw on the right side seemed to do little, but the best vacuum I could get was 15-16 inches.
Then I set the idle screw to about 900 RPM
Old 11-07-2020, 09:45 AM   #11
geezer#99
geezer#99's Avatar
Set your idle when hot at 750 rpm.
Then check your initial timing.
If it’s below 10 degrees bump it up to 14 degrees. Plug off vac advance line doing that.
Check your idle is at 750 again.
Adjust your mix screws.
See how that works.
Is your vac advance hooked to ported or manifold vacuum port?
Old 11-07-2020, 09:47 AM   #12
kens65fb
See how that works.
I don't have a timing light, I am using ported vacuum.
Old 11-07-2020, 09:59 AM   #13
geezer#99
geezer#99's Avatar
If you’re gonna get it running right you need a timing light.
A digital or dial back type works.
Or you could set the timing like I learned to 50 years ago.
By ear!
Advance it until it pings, back it off a touch. Lock it down, adjust idle down to a guesstimated 700 and test drive.
Old 11-07-2020, 10:07 AM   #14
geezer#99
geezer#99's Avatar
Two weeks ago I gifted one like this to a new mechanic in training.
https://www.summitracing.com/parts/s...iABEgLe8vD_BwE
Old 11-27-2022, 01:17 AM   #15
guyryan100
guyryan100's Avatar
Harbor Freight has a cheap one with dial back feature, worked great for me.
guyryan100 is offline   Reply With Quote
