Old 11-06-2020, 03:37 PM   #1
Big70
12 bolt posi information
So I just purchased a 12 bolt Posi rear end. It’s a truck rear end with the track bar. it has 373 gears in it. My question is how many different spline axles do these come with? I was reading somewhere that they come with a course axle? Looking to see any and all info on this. Basically I’m looking to be able to buy all new bearings and seals for it and just freshen it up and put in my truck
70 custom10 swb fleet side 454 th400
Big70 is offline   Reply With Quote
Old 11-06-2020, 04:54 PM   #2
gmc684x4
Re: 12 bolt posi information
You can look on the right side tube for code stamping which can help confirm year of manufacture
Late 70 and up axles will be a bit wider 63 to 69 axle will be a bit narrower
gmc684x4 is offline   Reply With Quote
Old 11-06-2020, 07:10 PM   #3
MDPotter
MDPotter's Avatar
I believe pre-66 has a different spline count than 67+. Otherwise, axle seals and bearings are the same.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
