Old 11-06-2020, 06:15 PM   #1
Big70
Identification of my 12 Bolt
Can you guys tell me what you know about these identification numbers? Really would love to know what axles are in here and what year this was built. From what I can see the the tube has HC 06 23 stamped and the housing has 147 cast into it. Thanks in advance!
70 custom10 swb fleet side 454 th400
Big70 is offline   Reply With Quote
Old 11-06-2020, 08:25 PM   #2
gmc684x4
Re: Identification of my 12 Bolt
HC 06 23 3.73 Posi gears 6 month 23 day 67 rear diff
http://67-72chevytrucks.com/vboard/s...d.php?t=486309
https://gmcpauls.com/67-72_chevy.htm
gmc684x4 is offline   Reply With Quote
Old 11-07-2020, 12:11 AM   #3
Big70
Originally Posted by gmc684x4 View Post
Do you happen to know what spline axels are in it? My dad said he heard of some thing about smooth spline? Never heard of it.
Old 11-07-2020, 12:41 AM   #4
gmc684x4
70 to 82 are 30 spline
I am guessing 67 to 69 are as well
67 to 82 12 bolts take the same axle seals and bearings
On the earlier 63 66 ones i am not sure
I never counted splines last time i changed axle seals on my 68
63 to 66 are a course spline from my understanding
On earler open diffs easy as changing spider gears to a 30 spline from what i have read
Are you looking to switch to 5 bolt axles ?
Old 11-07-2020, 10:46 AM   #5
Big70
No sir. Just trying to make sure that I buy all the right bearings and seals. How could you tell that it’s built in 67? I have a 12 Bolt in there right now that I hurt. I just acquired this 12 bolt with 373 gears that I want to put in there with all fresh seals and bearings.
Old 11-07-2020, 11:30 AM   #6
gmc684x4
Google I found a table excerpt from the new SA design book 67 72 chevy trucks
Has a table listing Diff stamp codes listed HC states 3.73 posi 1967
Gmc Pauls also hase code Hc listed as 3.73 posi no year listed
If you choose look inside on there site page 103 I see they List it in 1969 so that code will be for 67 to 69
https://www.cartechbooks.com/how-to-...1967-1972.html
Old 11-07-2020, 07:58 PM   #7
Big70
One thing I’m trying to figure out is why the 12 bolt I have under the truck is 57 inches backing plate to backing plate but the 12 bolt I just got is around 55 1/2? The truck was a step side before and from the looks of things the narrower 12 bolt is going to go in just fine. Did they make a wider 12 bolt for step sides or some thing? Every thing seams like it’s going to line right up it’s just narrower.
Old 11-08-2020, 01:27 AM   #8
gmc684x4
What is the axle number of the diff in your truck ?
I would guess and say its a 70 to 72 diff there a bit wider
Old 11-08-2020, 12:51 PM   #9
Big70
The axel number? Is that part of the #’s that ar stamped into the tube or number that is cast into the center section?
Old 11-08-2020, 05:28 PM   #10
gmc684x4
Be the stamped numbers like your new dif on the axle tube
Old 11-08-2020, 06:25 PM   #11
LockDoc
The Older Generation
LockDoc's Avatar
Here are the ratio charts I posted on the board back in 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc
Leon
Old 11-08-2020, 08:42 PM   #12
Mike C
Mike C's Avatar
1970 was a changeover year. It should have the wider housing same as 71-72. The 67-69 trucks had the narrower housing.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
