![]() Join Date: Sep 2002
Panhard bar affect ride height?
My swb 65 c10 sits a little lower on drivers side. It has a static drop of 3/4 with new springs all around. Originally I installed 3" drop in the rear but changed out to 4" as it looked too high. Thing is I noticed the same with either springs, maybe an 1" difference in height between the 2 sides in the back (drivers side lower).
Was wondering if the panhard bar adjustment could affect or cause something like this to happen. The bar is a CPP adjustable, all parts including springs, shocks, and bar were new when installed. Any info or suggestions would b most appreciated. Thanks
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: Panhard bar affect ride height?
You need to add a 1/4-3/8 spring spacer to driver front, it is common for this to happen, mine was the same way and now its dead level.
Thanks very much for the info. Could u explain how adding to the driver front will level the driver rear? Any idea why this is a common issue?
Thanks again.
I can't explain it but it does, mine went up over 1.25" in rear with a 3/8 spacer, I was told buy a guy that worked on the line in the 60's that they had these at their disposal. If a car or truck came down with a lean they woul;d insert a spacer, it is very common for driver side to be sagged , no ideal why.
![]() Join Date: Jan 2011
I have swapped springs from sis to side also. The springs we get for these trucks seem to vary just a bit. It only takes 10 to 15 pounds per inch on the rates to make a truck sit a bit off in the rear. The back of these trucks are are torsionaly flimsy and it does not take much to make em twist and not sit level.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
