Trim
Good afternoon,
On my 72 C20 im stuck on trim issue. Do All 72 C20 Cheyenne Have upper and lower trim or just lower? Mine has lower but There is none whatsoever any indication if it had at one point Upper trim. There are no holes for upper anywhere to be seen. Is there any links or does anyone know about this? Pictures for attention Thanks Zibs71 |
![]() Join Date: Oct 2009
Re: Trim
For a Cheyenne, lower is standard (and is of the woodgrain variety), upper is optional. If your truck still has a SPID sheet on the glovebox door, you can confirm if yours was ordered with upper. Upper was also mandatory for a deluxe two tone paint job. So, another way to tell (if your SPID is intact) is to look for a 400 series paint code, which generally indicates a factory deluxe two tone paint job.
Re: Trim
Here is my SPID Sheet
Zibs71 |
Re: Trim
Your white has been added and no upper trim originally. Nice truck!.
Re: Trim
Thank you Jocko
So my 72 C20 was originally yellow and white was added at some point? I really like the yellow/white combination. When I get it painted im goung to paint it the way it is now Thanks again Zibs71 |
Re: Trim
Yes, your original paint was solid 525 Yellow (aka Grapefruit Yellow). Lots of people prefer the deluxe two tone version. Below is a fellow member's beautiful K10 (that I had the pleasure of meeting down at C10s in the Park a few years back) in the 464 RPO paint scheme - i.e. your 525 Yellow with 521 White (Frost White) as the secondary color in a Deluxe Two Tone paint scheme. Note that on the factory deluxe two tones, the door frames around the windows were white also and there is also bright paint divider trim around the back of the cab to separate the roof white from the primary color. Your Cheyenne would have had a woodgrain tailgate band instead of the big painted letters.
Re: Trim
Thanks jocko for all that information. I've never come across a
woodgrain tailgate band. Mine obviously is different. Attached is a picture cause I'm not 100% sure Zibs71 |
Re: Trim
What you have is correct, the woodgrain is just weathered. Here's a pic of one for reference, they are available at places like LMC and several other vendors. Here's the LMC one: https://www.lmctruck.com/1967-72-che...te-bands-color I also thought someone sold the woodgrain tape only to repair one's own trim - but can't find it - it may have been for the lower trim only and not the tailgate bad.
Re: Trim
Thanks jocko
I'll look into lmc for that. Now to find a door or at least measurements so I can Fab one for my built in toolbox on side of box Zibs71 |
![]() Join Date: Mar 2012
Re: Trim
I say good luck as that is one rare piece (NOS) to find
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Re: Trim
Hey bigmac73
I'm beginning to wonder if ill ever find a door for my toolbox I prolly got a better chance to win a lottery lol....I dont even know anyone that I could grab the measurements from. Then I could at least fab one Zibs71 |
![]() Join Date: Jul 2015
Re: Trim
A guy on the FB fourm has one for 800.00
#13 |
Re: Trim
Uh did you say 800.00?
Wow !! Zibs71 jcfcamaro, Do you mean the Facebook page with is sire on FB? |
#14 |
tool box door and compartment insert
https://www.ebay.com/itm/1967-72-Che...EAAOSwzmZfrR7m
950.00 for this one on ebay Door and tool box insert. |
