Old 12-17-2003, 12:36 AM   #1
gmc71
gmc71's Avatar
alternator ???
The trucks alternator is wired for a square plug in the back, I have a few newer ones laying arround (rectangle, or flat on top) what do I need to do to convert? Is it worth it? Are there any advantages to the newer models?
Also.... in the alternator wiring harnes section there is a light blue wire, where does it go? what is is for?
Thanks in advance
gmc71 is offline   Reply With Quote
Old 12-17-2003, 11:18 AM   #2
JimKshortstep4x4
Talking
Going with an internally regulated alternator is a good upgrade. (Alternator with the rectangular plug). Square plug is the older style with the external regulator.
I believe the blue wire you are asking about is the exciter wire from the ignition. It should read voltage with the key on.
Here is a link to discussion on upgrading to an internally regulated alternator.
Jim
http://67-72chevytrucks.com/vboard/s...tor+and+change
Old 12-17-2003, 12:03 PM   #3
rickspickuppart
for 15.00 you can get the conversion kit and not have to cut or modify anything and it eliminates having to modify any wiring at the regulator side.
Shawn
rickspickuppart is offline   Reply With Quote
Old 12-17-2003, 10:31 PM   #4
ZOOMY
barn9
barn9 sold me a couple kits about a month ago. He might still have some.
ZOOMY is offline   Reply With Quote
Old 12-17-2003, 10:45 PM   #5
rickspickuppart
If not I have some
Shawn
Old 12-17-2003, 11:13 PM   #6
dinnut
dinnut's Avatar
is this interally or externally regulated?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-17-2003, 11:19 PM   #7
gmc71
gmc71's Avatar
Thanks, I'll look into that
72 Chevy 4x4 350
55 Chevy Bel Air 350/350
53 Matchless G80s (motorcycle)
06 Trailblazer SS 400hp LS2
