Old 11-13-2020, 06:44 PM   #1
Furno68C20
250Ci swap to a 355ci What needs to be changed
I'm about to start removal of a i6 250 engine and swap for a sbc v8 355ci.
The truck is a 67 3 on tree.
My question is what can be used and what cant be used? Radiator? clutch? flywheel? pressure plate? starter? ect....
Need to make a part list to order for the job to run as planned.
for now going to use the 3 speed that in there until i find a 4 speed saginaw or t10.
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Furno68C20 is offline   Reply With Quote
Old 11-13-2020, 11:15 PM   #2
gmc684x4
Re: 250Ci swap to a 355ci What needs to be changed
Depends on how much hp your new engine puts
I used my rad starter clutch etc you will need a v8 zbar for the clutch pedal
350 will drop right in place on the motor perches as well
Rubber mounts will bolt onto the block as well
I did this with 200 hp 70s square truck engine
gmc684x4 is offline   Reply With Quote
Old 11-13-2020, 11:48 PM   #3
Furno68C20
Old 11-13-2020, 11:51 PM   #4
Furno68C20
300-315 hp engine. Mild cam vortec heads. Nothing too crazy. The math spits out 10:1
Old 11-14-2020, 12:52 AM   #5
gmc684x4
New engine i look at a new rad used engine i am more willing to take a chance on an old rad an old rad in these gals can be well over 50 years old
I am getting a 2 core all aluminum rad for my 72 it will be pushing somwhere over 400 hp
Either way you will want to use a good fan shroud to help keep her cool
Old 11-14-2020, 10:19 AM   #6
67mater
67mater's Avatar
the Z bar I think is the same, it's the block side mount that is different. the inline 6 is wider to make up for the block being farther away.
the throttle linkage and pivot are 6 cylinder only, assuming you are running all stock.
if your clutch is the 11" one you could get way with reusing it. Would not recommend the 10" with a v8, but it ill all bolt up and work.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 11-14-2020, 12:29 PM   #7
tim_mc
tim_mc's Avatar
I left my SBC in the i6 position as well. The HEI is close to the firewall, but there's enough clearance to pull the distributor when needed. For the fan shroud you can use one for a 4x4 V8 as 4x4s had the V8 in the inline 6 position. I got mine from LMC and like it (p/n 32-2826).
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 11-14-2020, 12:37 PM   #8
tim_mc
tim_mc's Avatar
Oh, you might also want to consider a newer throttle cable setup instead of the pushrod. There are a few threads on here that detail the changes and mods needed.
Old 11-14-2020, 02:07 PM   #9
Furno68C20
Planning on keeping mostly stock. I’ll have to check the clutch diameter make sure it’s 11.
What about the radiator supports?
The oil pressure sensor? 6 cyl is wired to the cluster. The sensor fits next to the distributor on the sbc which usually is hard tubed the dash.
