Fan stat/ Water temp ports
So, i need a port for temp sender and one to operate an elect. Fan, , ill use the intake, for one, Any options other than the head? Its for a dakota sensor and really dont wanna run it that close to a header
![]() ![]() Join Date: Oct 2014
Re: Fan stat/ Water temp ports
It looks like you are using an SBC for an engine. Does your water pump have one of these outlets on top of it, like this one? Can you use it? Or maybe something like this in the link below?
https://www.summitracing.com/parts/a...EaAuC7EALw_wcB Here's more to look at too, https://www.summitracing.com/search/...ender-fittings |
#3 | |
Any port on the water pump is not ideal. They’re intake ports.
They make thermostat housing spacers like this. Likely better than the hose fitting. https://www.summitracing.com/parts/m...SABEgI5cPD_BwE |
i made mine for the lower radiator hose that has worked fine for the last 36,000 miles
short piece of 2" ss exhaust tube with half a 3/8" couple welded in it
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
how about a pic of your engine so we can see what you have available
I should have been more specific i guess, lol, i can see what i have available, one on intake, one on each head, and heater hose connections, i guess i was looking for things like dual adaptors, t fittings etc...but im thinking the best and cleanest option is to just use the head port and a heat sleeve. To protect the sensor and wires
