Old 11-15-2020, 08:30 PM   #1
plumbers crack
plumbers crack's Avatar
West Coast mirrors
Anyone know if there is a set of west coast mirrors that use the regular mirror mounting locations on the lower portion on the door?
I'm putting a service body on my crew cab and I'm thinking a set would look alot better than the regular and I don't want to cut or weld my original doors to fill the regular mounts.
1990 GMC R35 CC dually, VE cummins, 47RH
2005 Silverado ecsb, 5.3, 2/4 drop, daily work wagon
2000 Yukon xl, 5.3 all stock, wife's truck
2007 Yukon Denali, 6.2 back up truck
plumbers crack is offline   Reply With Quote
Old 11-16-2020, 08:35 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: West Coast mirrors
Not sure what you mean by regular mounts...but there are many different bolt patterns for west coast mirrors depending on who made em...when I got my 81, there were 13 holes in each door left by the po where all the different style wc mirrors had been bolted on and torn off over the yrs...
May not be easy to find what your looking for
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-16-2020, 01:14 PM   #3
1976gmc20
The thing about the WC mirrors is that they do obstruct your vision at intersections. Hence in the 1970s they invented the "below eye line" mirrors (3 pt, 4 pt, and now the new fancy ones).
I bought a set of something like "Velvac" (?) WC style mirrors that had two separate mirrors one flat and one convex so you could see between them. Had to drill new holes above and below window of course. The friction hinges wouldn't hold at highway speeds so I rigged a guy wire back to the base plate of the little factory mirror that I took off. Worked good for off roading because I could just un-do them and fold back.
My big GMC had a roof mounted set of trailer toter mirrors including a roof rack. The WC mirrors were suspended from square tubing that ran clear across the top of the cab and telescoped in and out on each side.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
