11-16-2020, 02:26 PM | #1 |
55-59 Wiring harness choices
I am planning for this winter's projects, or steps to take to get my truck on the road for spring. The one big question is "what wiring harness should I use"
I have 2 or 3 original fuse boxes I could rewire, I could pull from a newer truck, or I could go with any one of the available aftermarket kits. This truck is kind of a basic, old-school restomod. 57 Chevy truck with a Nova Clip, 10-bolt rearend on a 4-link, SBC with a carb, and a TH350 which will be changed out for a 700R-4. Either an HEI distributor or an MSD/Crane or other spark box. The truck may get AC down the road, but I will keep the manual windows and locks. I have no intention to ever go with an LS motor, or fancy 5 to 12 speed electronic transmission. If I go fuel injection it will be FItech, so this would not effect my choice with the wiring harness. I have used a Painless Kit on a '69 in the past and was not a big fan of it, but it was my first kick at the cat. I did not like the fact that a kit specifically designed for 67-72 trucks had instructions that said Step 1: Cut the dash. Based on price and quality, which way would you recommend? thanks |
11-16-2020, 05:57 PM | #2 |
Re: 55-59 Wiring harness choices
I have AmericanAutowire in my 57 --- it does all that i need or want .!!
11-16-2020, 06:47 PM | #3 |
Thanks Daze57. Does AAW supply the pigtails for headlights, turn signals, heater, ignition, tail lights etc?
Painless only supplied real cheap headlight pigtails with crappy wires. Did you get a Hotrod kit or one for a Taskforce? |
11-16-2020, 10:02 PM | #4 |
Post Whore
I also used AA...VERY pleased with the quality ...and the ease it installed...I used the highway 15...no light pigtails come with it...but it does have new ign and light switches
11-17-2020, 01:01 PM | #5 |
Cameo
i am using the classic update kit from AAW it has all the lighting connectors for my 57 . Instructions are laid out very well with all color diagrams plus each wire is labeled as to what it connects to. i am v satisfied with this kit ---i know it aint cheap but it has everything plus more that ya need to fully rewire your truck --check out their website. i was very hesitant on wiring my truck ....AAW made it v easy . good luck sir Hail Canada !!!! |
