alternator help Please
OK here's my question for the experts.. I want to retain my original date coded
delco alternator but would prefer to convert it to internal regulator.. I could very easily bolt a 1 wire on but I really wanted to keep my original alternator but do away with the troublesome external regulator.. does anyone make a kit to convert these? |
Who Changed This?
![]() Join Date: Jan 2013
Re: alternator help Please
There is no room inside an alternator without an internal regulator to put said regulator.
Who Changed This?
I'd like to do the same, but also don't want to lose the original look. There are only a few things that aren't original, but I'm not letting the disc brakes hurt my eyes.
![]() Join Date: Apr 2016
You can upgrade to a solid state regulator, and take the can off of the original regulator and put it on the solid state regulator. It will look very original but have modern guts. I don't think there's any super advantage to an internal regulator vs. a solid state external regulator.
#6 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#7 | |
Who Changed This?
The Wells and Autozone part number is VR715. I have not had one but there have been discussions here on the forum about them.
I was thinking you can use the front half of the alternator with the date code and swap on the back half to one with internal regulator style case? You lose the "look" but keep the date code.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
I thought about that and will give it a twirl later this week
The first image is the bottom of a typical, original style Voltage Regulator. They usually have two wire wound, ceramic resistors on the bottom.
The Solid State Regulator in the second image has no exposed resistors and because it has no relays inside, can easily weigh less the half as much as the original style relay. Most FLAPS sell the solid state regulator in the neighborhood of $30. The original style regulators sell in the $50 to $70 dollar range or more. You could put an original DELCO cap on either one, if that's important to you. Most FLAPS now sell rebuilt 10DN Alternators with a rating of 55 Amps. Summit racing even has one rated at 100 Amps.
'67 GMC 2500, 292, 4spd, AC |
