11-17-2020, 06:53 PM | #1 |
Turbo 200r 4 identification
I’m looking at a 200R4 tranny , it has a ID tag that says HC F , any idea what type of car it came out of ? I tried to search , but no luck.
11-17-2020, 07:13 PM | #2 |
Re: Turbo 200r 4 identification
Duh, early to mid 80's GM. Sorry No help I coudn't resist. Good luck. Jim
11-17-2020, 07:37 PM | #3 |
S10 had them not sure about hcf
11-17-2020, 11:26 PM | #4 |
11-18-2020, 08:20 AM | #5 |
S-10's Never came with them, and never is a dangerous word. The S-trucks had 700R4, or in the first two [ I think model runs] TH125C [three speed]. I have had at least one of every year model S truck That used to be my thing along with the full sized Chevy trucks from then but I always said the S trucks were my bread and butter. This thread makes me sound jerkish and that isnt me, or at least I dont think it is.
11-18-2020, 08:22 AM | #6 |
Monte Carlo SS is the best to find but that is plenty rare. The 200R came in Regals And most all G body cars and intermediates from the General. There are even some dual pattern meaning they will work on just about anything GM
11-18-2020, 09:51 AM | #7 |
From what I understand is they are made to fit most GM products including chevy, Pontiac, Oldsmobile, Buick, etc. The one I just installed in my truck came out of a 86 full size chevy wagon. The ones that were installed in the 442's, Monte Carlo SS, GTO, etc. were the same as regular cars, but have a beefed up valve body which could be installed in any of the 200-4R's. They are getting a little had to come by, especially the muscle car ones. Unless your going to beat the hell out of it, it shouldn't make any difference.
11-18-2020, 12:03 PM | #8 |
Yes they have been hard to find for a while, I searched craigslist religiously for about a year before I found one. Have not installed it, just stashed for now, plan is to put it in my 40 Ford Coupe eventually.
11-18-2020, 06:20 PM | #9 |
They are the popular g-body platform OD trans as mentioned. Strength wise (stock) they're similar to a 700r4. Their benefit is in the gearing. The 1<2 gear split is closer to a TH350/TH400 vs. the 700r. OD is a little more aggressive as well (.67 vs. .70).
The MCSS, Olds H/O's, & GN/T-Type Buicks did have a specific valve body & stamping to make them easier to spot but I don't recall what it was & doesn't make much difference if you're upgrading for an aftermarket/different drivetrain. Easy to spot them though as the pan is long & has 16 or 17 bolts (I don't recall which it was).
11-18-2020, 11:29 PM | #10 |
Plan on putting it in my 72 1/2 to ,stock 350 with 3:08 rear
11-19-2020, 01:35 AM | #11 |
That's going to be super tall gearing for OD speeds. What tire size are you planning for on the rear axle?
11-19-2020, 08:29 PM | #12 |
235/75 /15 tires , totally stock truck
11-19-2020, 11:37 PM | #13 |
Thats 1685rpm @ 65mph & 1800 @ 75mph.
A 60's-80's sbc in a C10 is going to need 22-2400rpm for the 'sweet' spot. 3.73's would yield about 2200rpm @ 75mph.
11-20-2020, 01:39 AM | #14 |
11-20-2020, 11:39 AM | #15 | |
People assume that 1600rpms = better for driving but sbc's/bbc's have a happy spot slightly above 2krpm. That needs to be the target. Even the later LS/automatic combos are set-up to achieve over 2krpm @ highway cruise speeds (manual trans cars are geared differently).
