Trying to source rims for my brake swap...looking for a resource
Man...didnt think this would be quite such a PITA. I’m converting my 67 to power disk up front and need to swap out the rims to facilitate the rotor/caliper (my drum brake wheels wont leave enough room). I’m having a hard time sourcing some stock rims from 71 and up. Wheelsmith said they need the diameter hub-to-caliper of the kit (I don’t have the kit yet....waiting to hear back from POL) and Coker isn’t sure if their wheel would work.
I’m running 15x6 (6 lug) with the “nubs” on the outside of the inner ring for the 10” hubcaps that I’d like to keep. It would be easy if I went with steel smoothies, but man I like these stock hubcaps. I’m gonna hit the junkyards Friday but thought I’d ask if anyone here has a good source for what I’m looking for besides Coker or Wheelsmith. Or maybe someone has a pair they’re looking to part with. Thanks. |
Re: Trying to source rims for my brake swap...looking for a resource
Are you going 6 bolt or 5 bolt?
Slightly more important is stock height spindle or dropped spindle? |
Have you bought a kit yet or still researching?
I see the pol kit bumps your rims out 3/4 inch too. Have you looked into custom built rims? |
#5 | |
Anyway, yes, I’ve got the dims I need from POL, so I’m going to get back with Wheelsmith today to see about getting some rims made up special. |
How much time do you have to do the upgrade?
Do you want to get it driving right away or do you have plenty of time? I’ve always tried to not get in a rush. One thing at a time. Hate to see you install your new kit and run into a problem like your new custom rims not fitting. I’d install the brakes then do all my measurements for wheels. |
Old member
Face book market place has several adds for the truck rally's.
Craigslist also. I don't know what you liking is but the Rev wheels are nice. http://www.rev-wheels.com/rev-wheel....=6130&cat=1268 Market place. https://www.facebook.com/marketplace...code=undefined https://www.facebook.com/marketplace...code=undefined https://www.facebook.com/marketplace...code=undefined https://www.facebook.com/marketplace...code=undefined
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#8 | |||
That being said, any aftermarket wheel (US Wheel, Wheel Vintiques, Early Wheel) for stock disc brakes should/will clear stock discs. The issue will be aftermarket/larger brake set-up clearances. Stock/OE 71-87 C/K10 D52 brake set-ups should not have any clearance issues w/a truck disc brake spec 15" wheel.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-18-2020 at 06:39 PM. |
All the info is appreciated guys. I ended up scoring a decent pair on FB Marketplace for 60 bucks. And it looks like all will clear according to the dims I got from POL. Thanks!
You got pics of this ‘decent pair’?
Curious what you found. |
