Are all transfer case slip yokes interchangeable?
Would the slip yoke for a 2006 Silverado 2500hd fit into a squarebody np208/241 transfer case?
Preliminary research indicates that they should. Is there any chance the "missing" 32'nd spline on some shafts will cause any trouble?" If they're a match, it looks like I could pull this newer shaft, have it shortened a few inches, and it would bolt right up to a 14-bolt axle from the same donor. This will likely be cheaper than changing the yoke on the 14-bolt to fit my old shaft. (No, a conversion u-joint is not an option)
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
| Bookmarks |
