Old 12-17-2003, 02:27 AM   #1
danadena1960
35x12.5 tire
I am thinking of ditching my 16.5x8.75 for a set of 15x12 rims. The question I have is will a 35x12.5 work and look ok on a 12" rim? Eventually I plan on going to a 37x13.5 when the price gets more reasonable.
danadena1960 is offline   Reply With Quote
Old 12-17-2003, 06:58 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Most manufacturers recommend 10" wide rims for a 12.5 tire. I've seen 12.5 tires on 12" wide rims and for street driving should be fine but you get the truck a little off camber and you'll probably loose the bead, wouldn't take much. Probably couldn't use the full load rating of the tire either. Even the 13.5 tire would be the same as the 12.5. Tires I've seen that recommend 12" wide rims are for example the 33/15.5-15 super swampers and in that case its 10-12" wide rim. Be careful.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-17-2003, 03:07 PM   #3
Beast388
Suburbans RULE!
Beast388's Avatar
I agree with Jim. A 15X12 rim is too wide for a 12.5" tire. I would go with a 15X10 or 15X8. Personally, I went with a 15X10 for my 35X12.5's.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 12-17-2003, 04:42 PM   #4
Destructo
Re: 35x12.5 tire
I suggest 8" rims for 12.5" wide tires, that way you won't blow beads as easily. If you run a 12" rim on 12.5" tires your going to blow beads easily, trust me I know from experience running 10" rims with 10.5" tires. Blew a bead twice in one day on easy ****.
Destructo is offline   Reply With Quote
Old 12-17-2003, 05:04 PM   #5
714x4lover
IF YOU HAVE 8 LUG ROTORS AND CAIPERS IN FRONT THE 15" WHEEL WONT FIT OVER THE CALIPERS
714x4lover is offline   Reply With Quote
Old 12-17-2003, 07:34 PM   #6
MJN
MJN's Avatar
What are you doing with your old 16.5's? and where are you located?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 12-17-2003, 07:35 PM   #7
CHEVYJEFF
CHEVYJEFF's Avatar
Thought you would just have to grind a little of the calipers. I am trying figure out which rims to go with when I do my 8 lug 14 bolt FF rear and 8 lug 10 bolt swap on my k5. Thought about bart 15X10 supertruckers but if 15 wont fit I gues it 16" for me
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 12-17-2003, 07:45 PM   #8
danadena1960
My old 16.5's will be up for grabs. I live south of Atlanta GA. Thanks for the info. on the 15's not fitting, back in the day I had a old drum type 2 wheeler, I didn't think about the calipers. Thanks again.
Old 12-17-2003, 08:42 PM   #9
714x4lover
wheels
hey no prob maybe you can just send the wheels to me and we will be square how does that sound? lonn
Old 12-18-2003, 12:28 AM   #10
chevy68388
king $h!t
chevy68388's Avatar
u can make 15inch rims fit the 8 lug set up just grind the backs off the calipers. just dont take to much
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s
chevy68388 is offline   Reply With Quote
Old 12-19-2003, 06:21 PM   #11
Beast388
Suburbans RULE!
Beast388's Avatar
Take a look at my picture above. Those are 15X10's (with 4.25" BS) on an 8-lug axle. It did take a bit of grinding to the caliper and modifying the caliper support, but they fit.
--Ben
71 GMC Suburban 4X4
The "Beast"
Old 12-19-2003, 07:30 PM   #12
danadena1960
Thanks all for the info!
I am looking at a set of American 15x10 81series wheels with a 4" back spacing Pete Paulsen has them for $77 each. Summit also has Bart's with 3 1/2 back spacing for $99 each.
Thanks again ya'll,
Dana
Dana
77 K-20 454
73 SS El Camino 454
68 SS Camaro 327
48 Chevy 216
755 John Deere
Old 12-19-2003, 09:01 PM   #13
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Beast388 what kind of axle stands are those? What Weight/size they are too...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 12-19-2003, 11:20 PM   #14
Beast388
Suburbans RULE!
Beast388's Avatar
Uh...those are just some cheap 2-ton AC Delco jackstands that I picked up at O'Reilly's for $20.
--Ben
71 GMC Suburban 4X4
The "Beast"
Old 12-20-2003, 03:02 AM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Here some I bought at Sam's for $30 I believe:
http://67-72chevytrucks.com/vboard/s...threadid=73812
