11-20-2020, 08:26 PM | #1 |
Active Member
1969 K10 longbed frame with k20 axles
This is a complete frame with 8 lug axles I put under it. The axles are a Dana 44 up front and a HO72 I believe in the rear. It has warn hubs up front that look in good shape and function smoothly. The frame has been blasted and coated. It has the engine crosssmember and transmission crossmember. Also comes with the transfer case mounting bracket. I did remove the small block engine stands for my other build but everything else is there. I just spent 1000 bucks getting it blasted and coated but want to focus on my other project so it is what it is. The frame is nice. And the axles I haven’t gone through at all yet but they roll nice and smooth so that’s a start! Posi rear end in it as well. Disk brakes up front. Came off a 71 blazer believe it or not. I’d like $1500 for the whole thing. I also have it for sale locally. Thank you
11-20-2020, 09:33 PM | #2 |
Active Member
Re: 1969 K10 longbed frame with k20 axles
Road trip!
11-21-2020, 01:27 PM | #3 |
Active Member
Update. Sold the axles locally, complete frame left $750 bucks!
11-22-2020, 06:31 PM | #4 |
Where in FL are you located?
11-22-2020, 07:05 PM | #5 |
Active Member
I’m in New Smyrna Beach, just south of Daytona off 95
11-23-2020, 02:15 PM | #6 |
PM sent
12-19-2020, 12:54 AM | #7 |
Active Member
Ttt price drop for frame 650
12-19-2020, 05:42 PM | #8 |
All about them K’s
Just an FYI longbed K10 and K20 use the same identical frame year for year, the only difference between the two is springs and axles. Might help you sell it easier if some one is looking for a K20 frame and doesn’t know this. good luck with it, that’s a great price for the frame.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-20-2020, 12:12 AM | #9 |
Active Member
Thank you, I thought a good price. Probably just far for everyone to get! Appreciate the info
12-21-2020, 12:39 PM | #10 |
Proprietor of Dale's Corner
That's a great price......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
