11-21-2020, 07:55 PM | #1 |
wood bed strip nuts
Just discovered the original are square 7/16 nuts. Does the replacement hardware also use the square nuts. these are at the cross pieces to the metal strip only, rest of the nuts I see are standard 6 point.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-22-2020, 12:24 AM | #2 |
Re: wood bed strip nuts
I just installed a wood bed kit from Brothers and all of the nuts are standard 6 point.
11-23-2020, 08:10 PM | #3 |
Thats good to know. Just need to find a socket for the square ones. BTW did you do it with the bed attached to the frame or did you pull the bed off?
11-23-2020, 09:55 PM | #4 |
It takes an 8 point socket , kinda works like a 12 point socket on a 6 point nut.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-24-2020, 12:32 AM | #5 | |
I did my shortbed stepside sort of 'on the frame'. Had to lift the bed about 4" to get to some the bolts along one of the cross sills. This whole job turned out to be WAY harder than it looks. If you don't have a shortbed-stepside than all of the strip bolts should be readily accessible without removing the bed. Regardless, if you have room it would be a lot easier job with the bed off of the frame. I used pine and carbon steel strips because wanted "original". Pine is a real PITA to stain/seal though and I had to prep/paint the strips and bolts. It would a LOT easier to use SS hardware and Oak boards. Last edited by Carl Spangler; 11-24-2020 at 12:44 AM. |
11-24-2020, 08:26 AM | #6 |
I agree that it is much easier to do off the frame, than trying to do it on the truck frame. I would definitely recommend buying a new stainless steel bolt kit and throw your old bolts away! I assembled my bed on some stands and then used long 2x4's to support the bed so I could move the truck back under when completed. One man operation, and no need for heavy lifting.
