Old 11-22-2020, 08:24 PM   #1
65truckowner
65truckowner's Avatar
3 speed on column hard to shift
A friend of mine has a 66 c10 with the 3 speed on the column. In cold weather it is hard to pull the shifter back to go into first. He can pull it in the garage where it is warm and let it warm up then it pulls back with ease. What should I grease or what else can I do to fix this?
65truckowner is offline   Reply With Quote
Old 12-14-2020, 09:23 AM   #2
CC's 62
Re: 3 speed on column hard to shift
I have the same issue during cold weather months. Not sure why or how to fix. Maybe someone will chime in.....I hope.
CC's 62 is offline   Reply With Quote
Old 12-14-2020, 09:26 AM   #3
65truckowner
I may just have to tear it down but was hoping for a quick fix someone has done
Old 12-14-2020, 05:02 PM   #4
TwoFiftyShifter
PB blaster is quick.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 12-14-2020, 05:14 PM   #5
cwcarpenter98
cwcarpenter98's Avatar
PB blaster or some WD 40 will work. If that frees it up some in the cold, it's probably old grease that is sticking and should be cleaned out and fresh grease applied. Member Lugnutz65 has a great write-up with pictures on his website about rebuilding a 63 steering column. The 64-66 columns are similar, so you should be able to use that as a good reference if you decide to dig into it a little deeper. https://lugnutz65chevystepside.weebl...n-rebuild.html
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-14-2020, 08:01 PM   #6
jayoldschool
Moderator
I just put new bushings on my linkage down at the trans, the old ones were gone. Made a huge difference in shifting.
jayoldschool is offline   Reply With Quote
Old 12-14-2020, 08:14 PM   #7
65truckowner
Thanks guys
Old 12-15-2020, 02:54 PM   #8
67GMCcampercruiser
We have always used diesel fuel to lubricate the linkage.
67GMCcampercruiser is offline   Reply With Quote
Old 12-15-2020, 06:16 PM   #9
CC's 62
Thanks Christian, I'll take a look at lugnutz write up.
Old 12-15-2020, 06:17 PM   #10
CC's 62
Thanks Jay, maybe that's all I need. I'll look into it.
Old 12-17-2020, 09:13 AM   #11
Riverstory
Riverstory's Avatar
Jay, where did you get your bushings? I have ordered but yet to receive - I was told that they may have been discontinued. Thanks
Riverstory is offline   Reply With Quote
Old 12-17-2020, 11:30 AM   #12
jayoldschool
Moderator
Bill's Truck Shop up here in Canada. Just did them last month, had them shipped in with a gas tank for a buddy's 67 GMC 910.
Old 12-17-2020, 02:04 PM   #13
1966shortwide
Just squirt wd 40 with plastic nozzle into collar were shift handle is pined and give several good squirts while working handle back and forth in neutral gate. It will loosen up right away, had one do that years ago. No need to year down
1966shortwide is offline   Reply With Quote
Old 12-19-2020, 08:21 PM   #14
65truckowner
Yes I pulled the steering wheel today and right behind the shifter I lubed it up good and cleaned it then lubed it again. Works better than ever now.
Old 12-19-2020, 08:31 PM   #15
1966shortwide
You would not had to temove wheel ,i never did but you got it now you can speed shift...lol
Old 12-19-2020, 10:12 PM   #16
Riverstory
Riverstory's Avatar
Checked with Bill's Truck Shop. They did not have any more. If you have a lead on any more . . . . Thanks
Old 12-20-2020, 07:27 AM   #17
The Rocknrod
Moderator
The Rocknrod's Avatar
Like these? - https://www.classicchevy.com/chevy-o...-340145-1.html
or - https://www.classicparts.com/1947-76...nfo/91%2D062B/
Shiftworks has Universal Linkage Grommets and the whole Rod Swivel Kits for shift linkages.
Old 12-20-2020, 08:15 AM   #18
Riverstory
Riverstory's Avatar
I recently ordered the 2 part grommets from American Classic Truck Parts and at one time, they had these and can no longer source them. Their part was 91-063 and those parts no longer appear on their website. The ones that I have are original and my intuition tells me they are gonna fail once I start driving this restoration.
These 2 grommets per shift rod are out of a 1966 C10 panel, three speed on the column.
Any assist in locating new replacements would be much appreciated
