Old 11-25-2020, 06:05 PM   #1
Todd68Chevy
Todd68Chevy's Avatar
Misc. Parts someone should need
Misc. Used 67-72 Parts. All prices plus shipping cost. Located in Shelburn, IN. For sale on other sites. Post to thread as per rules. I only accept PayPal and postal money orders
Small block engine stands. Grease included $45
S/B balancer bolt with washer $5
S/B dist hold down clamp $5
Inner fender to cab bolt with large washer $7 each
67-70 rod style throttle pedal arm (rusty but solid) & hold down $11
Wiper motor to linkage crank arm no clip $8
Brake pedal to rod shoulder bolt and nut $6
Upper 3 core radiator hold downs with rubber cushion $16 pair
Power steering pressure hose (used unknown condition but looks ok), P/S return tube off of gear box and frame hold down clamp with bolt. $25 all
Steering column to dash cluster trim $11
Steering column to pedal assy. Bracket $11
Steering column to firewall bracket with clamp $15
Auto steering column linkage with frame bracket (everything used with some wear) $38
Pedal assy brace with pedal stops $7
Used Mounts and bolts for standard shift transmission bell housing mount $22
Parking brake parts from a long bed rear coil spring suspension frame:
Left side rod with cable slide $15
Intermediate cable $10
Inter. Cable to rear cable connector clips $11 pair
Cable slide at front cable connection $8
Cable support hooks $11
67-68 parking brake handle cover $22
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 11-25-2020, 06:45 PM   #2
jimer1964
jimer1964's Avatar
Re: Misc. Parts someone should need
I will take the sb balancer bolt with washer shipped to Pa 17517
jimer1964 is offline   Reply With Quote
Old 11-25-2020, 07:52 PM   #3
anew4961
I will take the shift linkage
anew4961 is offline   Reply With Quote
Old 11-25-2020, 09:37 PM   #4
Willys_MB
Willys_MB's Avatar
I could use a fender bolt with the big ass washer and the 67-68 parking brake cover. Can you pm total with shipping to 83646? What’s the condition of the transmission mounts?
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 11-25-2020, 10:16 PM   #5
Todd68Chevy
Shipping is $6.05 USPS first class mail or $8.00 USPS priority mail so your total will be 11.05 or $13.00 depending on which shipping you want. Let me know. Thanks.
Old 11-25-2020, 10:23 PM   #6
Todd68Chevy
Ok, Thanks. I will need your shipping zip code to figure shipping cost. Thanks.
Old 11-25-2020, 10:56 PM   #7
Todd68Chevy
Ok, I have more bolts if you need a pair. For 1 bolt and the brake handle cover $42.65 shipped USPS priority mail.
The bell housing mounts look like good used condition to me. The total for the fender bolt, handle cover and bell housing mounts is 66.05 shipped USPS priority mail.
Old 11-25-2020, 11:01 PM   #8
Todd68Chevy
Cover picture.
Old 11-25-2020, 11:58 PM   #9
anew4961
27217 thanks
Old 11-26-2020, 12:09 AM   #10
jimer1964
jimer1964's Avatar
I will go priority get me your Payment information Thanks
Old 11-26-2020, 11:04 AM   #11
Todd68Chevy
27217 thanks
$12.25 USPS priority mail so a total of $50.00. I will PM you payment method. Thanks
Old 11-26-2020, 11:08 PM   #12
Willys_MB
Willys_MB's Avatar
Ok, I’ll skip the mounts. I have a set on the truck already, but the part-hoarder in me wants another set “just in case.” What’s your PayPal address? I’ll send $42.65 in the morning
Old 11-26-2020, 11:30 PM   #13
Todd68Chevy
Ok, PM sent with PayPal info. Thanks
Old 11-27-2020, 10:00 AM   #14
heehawracing
heehawracing's Avatar
How much for all the steering column brackets shipped to 30276
heehawracing is offline   Reply With Quote
Old 11-27-2020, 11:17 AM   #15
Willys_MB
Willys_MB's Avatar
Paypal sent! As I said in the PM, I only need one fender bolt.
Thank you!
Old 11-27-2020, 05:58 PM   #16
Todd68Chevy
These pieces or do you want the trim? $42.30 for what is pictured including USPS priority mail shipping. Or $32.30 for just the brackets without the dash trim filler including the shipping.
Old 11-27-2020, 07:46 PM   #17
heehawracing
yes all those and the big square bracket that goes under the
column
Old 11-27-2020, 08:18 PM   #18
Todd68Chevy
column
$51.00 shipped for all parts previously pictured and this bracket.
Old 12-10-2020, 09:30 PM   #19
Todd68Chevy
Pictures for Cericd.
Old 12-11-2020, 03:22 PM   #20
68Gold/white
Todd,
I assume the shift linkage sold???
Do you have any more (a complete set?)
Jeff
68Gold/white is offline   Reply With Quote
Old 12-12-2020, 12:00 PM   #21
Todd68Chevy
Originally Posted by 68Gold/white View Post
Todd,
Jeff
I know I have parts but I don't think I have another complete set. I will check when I get time. Thanks, Todd
