Old 11-25-2020, 09:21 PM   #1
68GMC2500
Frame question 1/2 ton vs 3/4 ton
I have a 1/2 ton long bed 4x4 and I was wondering if it's worth it to you upgrade to a 3/4 ton frame I have 3/4 ton axles and springs. Going to be doing some towing. Any thoughts or advice thanks
Joe
68GMC2500 is offline   Reply With Quote
Old 11-25-2020, 09:34 PM   #2
Ziegelsteinfaust
Re: Frame question 1/2 ton vs 3/4 ton
I think the frames are the same on the 4x4 1/2 + 3/4 tons.
As far as towing it depends on where you draw the line. If its a ocasional 7000 pounds i don't see it worth the effort. If it is alot of towing, and closer to 9000 pounds then a 3/4 ton will be the ideal choice.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-25-2020, 09:42 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The frames are the same.
What are the 3/4 ton differentials you have out of?
66 C20 Service Truck:
Old 11-25-2020, 11:17 PM   #4
Captainfab
60-66 Nut
I've never had a K20 but the C10 and C20 frames are not the same. The C20 is stamped from heavier gauge steel and has extra bracing.
Old 11-26-2020, 12:19 AM   #5
LostMy65
LostMy65's Avatar
Sorry Captain,
I guess I was repeating what I heard without knowing for sure myself.
Thank you.
Old 11-26-2020, 07:46 AM   #6
68GMC2500
Thanks y'all
Will be towing about 7000lb
Old 02-19-2021, 09:57 PM   #7
LostMy65
LostMy65's Avatar
Found this in another thread:
½ ton 2WD: 6-1/32 x 2-1/2 x 5/32
¾ ton 2WD: 6-1/8 x 2-17/32 x 3/16
One ton 2WD: 8-1/8 x 2-13/16 x 3/16
½ ton 4WD 115” WB: 8-1/32 x 2-25/32 x 9/64
½ ton 4WD 127” WB: 8-1/8 x 2-13/16 x 3/16
¾ ton 4WD: 8-1/8 x 2-13/16 x 3/16
As you can see, even the ½ ton 4WD long bed uses the same size frame member
as the one ton 2WD.
1960-62 frame ,measurements
½ ton 2WD: 5-15/32 x 2-1/4 x 1/8
¾ ton 2WD: 7-3/16 x 2-3/4 x 3/16
½ and ¾ ton 4WD: 7-13/64 x 2-3/4 x 3/16
Old 02-19-2021, 09:59 PM   #8
LostMy65
LostMy65's Avatar
Do the 63-66 4x4's really have a taller frame channel?
Old 02-19-2021, 10:10 PM   #9
68GMC2500
Thanks guys, looks like some good information for me and other members.
Hope to be doing my upgrades this summer.
Joe
1963 chevy original k10 long bed fleet side
Old 02-20-2021, 06:32 PM   #10
LostMy65
LostMy65's Avatar
as the one ton 2WD.
So, the 3/4 ton 4x4 frame is heavier than the 3/4 ton 2wd?
Old 02-20-2021, 08:19 PM   #11
68GMC2500
That'll work perfect
I have a 63 K10 long bed so going by that chart I'll be fine, just need to install my 3/4 ton axles in springs
Thanks all
Old 02-26-2021, 08:09 PM   #12
LostMy65
LostMy65's Avatar
Could someone please verify that the frame for the 4x4's are actually 8 inches tall?
Old 02-26-2021, 10:09 PM   #13
66x3
I can check tomorrow ,66 K 20 4x4 and let you know.
66x3 is offline   Reply With Quote
Old 02-27-2021, 02:00 PM   #14
66x3
Confirmation: My 66 K 20 frame is somewhere between 8-8.25 measured from about the center under the cab. Didn't want to roll around in the snow to check further!
Old 02-27-2021, 11:19 PM   #15
LostMy65
LostMy65's Avatar
Thanks.
I wonder if they made the frame taller because a 4x4 may need to resist more twisting.
