Old 11-30-2020, 08:35 AM   #1
Zippi
Zippi's Avatar
*Fuse Block ID*
I'd like to put a cover on my fuse block but not sure what would fit. Can anyone ID my fuse block so I can buy a new cover or look for one at the junk yard? Anybody ever fab one up? Pics would be nice. Thanks guys.
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
https://zippi6.wixsite.com/adtruck
Zippi is offline   Reply With Quote
Old 11-30-2020, 11:42 AM   #2
jweb
jweb's Avatar
Re: *Fuse Block ID*
That looks like a 70's-80's GM fuse block. Most of those didn't have covers.
Like this:
https://www.ebay.com/i/141610254124?...iABEgISNfD_BwE
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 11-30-2020, 06:21 PM   #3
Zippi
Zippi's Avatar
Re: *Fuse Block ID*
Like this:
Yup.....I now know this. Thanks for the info.
1949 5 Window 3100
Old 11-30-2020, 10:00 PM   #4
PDW HOTRODS
PDW HOTRODS's Avatar
Re: *Fuse Block ID*
You would be better off making one, it would look better too. I would get some plastic sheet about 1/8 thick and make a flat cover with 4 sides bent like a shoe box lid. You could heat the plastic to bend it or cut and glue it together. then build up and glue magnets under the back side over the bolts and stick it to the heads of the bolts holding the fuse box to the truck. Sheet metal would work too but could spark if too close. You could cut holes in it over the flasher units.
PDW HOTRODS is offline   Reply With Quote
Old 12-01-2020, 07:45 AM   #5
Zippi
Zippi's Avatar
Re: *Fuse Block ID*
Thanks for the info. Your avatar is not showing up.
1949 5 Window 3100
