Old 12-17-2003, 04:44 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Question Cutting the Frame
Anybody ever cut a hole in their frame with a hole saw. I need to cut some holes through a cross member for exhaust and thought I would try a hole saw first. I only need to cut two holes and was wondering if one one of those bi-metal ones from Lowes or Home Depot would work. Wasnt sure how hard the frame is.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 12-17-2003, 04:55 PM   #2
Randy70C-10
Randy70C-10's Avatar
A bi-metal blade should cut right through it.
Randy70C-10 is offline   Reply With Quote
Old 12-17-2003, 05:02 PM   #3
Rooster's 67
Rooster's 67's Avatar
slow speed and dont force it you will burn the bit, If you can, find some cutting (lube) spray for it, it helps to lube and cool the blade.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-17-2003, 05:14 PM   #4
72BLAZERDUDE
Thanks guys, I will go ahead and get one and try that. Using a torch anywhere near those gas lines makes me nervous.
Old 12-17-2003, 05:49 PM   #5
cdowns
cdowns's Avatar
not a problem i've used them to cut thru 1/4inch steel, like stated slow and easy use something to lube it and cool the blade oil/wd-40 will work
Old 12-18-2003, 12:13 AM   #6
Vince M
Vince M's Avatar
Also grab a hold of the drill REAL TIGHT. The bigger the hole saw the more it will want to break your wrists.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 12-18-2003, 01:44 AM   #7
Rooster's 67
yes and dont put your apendages inbetween the drill and any metal because it will smack the bejeepers out of your apendages
