Thoughts on a Four 2bbl intake Manifold
I have the opportunity to but an Offenhauser 4-2bbl manifold, complete with the fuel lines and linkage.
This thing pegs out the Cool Meter For a long time now, I’ve been toying with the idea of building an engine and using a multi carb setup. My concern is the total CFMs of all the carbs, and how much engine I would have to build to be able to handle them. . Any thoughts from the Old Timers? Old School Rules! |
![]() Join Date: Mar 2003
Re: Thoughts on a Four 2bbl intake Manifold
You'll have "the cool'' factor going for you, that's about it. Old tech. I think a single 4bbl would be easier to maintain and adjust
I say go for it. That would be so cool at the car shows. I would try it. That being said most folks can’t tune a single carb correctly, let alone 2, 3,........ What’s the worst that can happen? You revert back to a single carb set up. Good luck, and post pics if you go for it. Lee.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#4 | |
Who Changed This?
![]() Join Date: Jan 2013
![]() Join Date: Jan 2001
If what you're looking for is something unique for showing, I think it would be really cool. If you're thinking about performance, it's going to disappoint you. Aside from that, it's going to be a chore to keep those four carbs tuned and synchronized.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Apr 2016
It sounds outrageous. I like it. I wonder if you could put adapters on it and hook up 4 Quadrajets. It would be fun to custom cut and weld together 4 stock style air cleaner housings to make one massive air cleaner housing with a row of snorkels. That would be style.
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
A four 2bbl set-up is appropriate for a small block, not a 6 cyl. 2-stage carbs would be cool and perform the best. Those multi-carb set-ups were all about WOT, just like a Torquer intake (straight runner/high-rise). It's style over performance with today's 4bbls available. If that's what you want then go for it. I think of the multi-carb set-ups, other that dual quad, as a '50s-early '60s thing on hot-rods with exposed engine. In one of these trucks it would be something you had to tell people or let them see with raised hood at a show. Dual quad would be period correct and was what I wanted on the 327 in my '67 project that is a period hot truck build. But I backed down once I considered while that is the look I want, the use I want from it is getting out of town... making long trips/touring around. Simple is good and so is using less fuel, so it's a single Quadrajet for that truck
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-03-2020 at 06:03 PM. |
Adding all the cfm's together isn't your total cfm. There is a formula to use. Example; if you use two 1000 cfm dominators, the total cfm you would think will be 2000 cfm. That would be a lot of cfm. I can't remember what to divide the total cfm by.
The best aspect of this forum is the seemingly endless wealth of knowledge and experience.
I wholeheartedly agree with all of the input and advice. For a long time, I’ve been dreaming of building an Old School Hot Rod engine, and then find something to put it in. If I had a 28-34 Ford Five Window coupe, this would be a slam dunk.Just for the cool factor at shows. I think the best app would be a Road racer or Dirt track car, and not a Drag Car. The ultimate goal would be to have this car on an Old School trailer, with my 70 as the Tow vehicle. Still can’t get my head out of the 70’s ![]() |
If you want to show it off and have a cool factor, go for it. If you want to drive it a lot and enjoy it, a single 4BBL will be much better. If you want to drive it and not worry about anything and get better mileage and way less fuel in the oil, fuel injection conversion.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
First of all, I don't have a clue what I'm talking about. Fortunately, that never stops me from talking
![]() I've wanted to do something similar for a while. I think it would be a much happier install with DBW throttle bodies. That would eliminate the hassle of fiddling with linkages, and it would let you tune each throttle body independently. There are controllers that do a fantastic job of tuning themselves these days. I know there is a cougar running a tunnel ram with dual TBs doing this. It's a street car with a small cube V8. It obviously gives up performance to run that intake, but it sure is cool. Particularly when you consider it has great street manners as well. There are a lot of ways to slice this problem. At the end of the day, if you like it, go for it! |
#13 | |
![]() This one runs fine and who cares about MPG ? It's about Smiles per gallon ! and I have a good Muncie connection , Great now you've got me thinking about another project ! https://www.youtube.com/watch?v=FtVfuWy3-Ts
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-03-2020 at 10:59 AM. |
#14 | |
Who Changed This?
#15 |
He lives about 1/2 hr away from Pigeon forge / Gatlinburg Tn , Arguably one of the biggest cruise in / car show destinations . Whats a little gas when you could have a bunch of fun ?
#16 |
![]() Join Date: Jul 2001
Have never seen or heard of a Offy 4-2BBL intake but have to admit the WOW factor at a car/truck show would peg the meter at top end. Just do not see very many multi-carb set ups anymore at shows. LS and EFI fever has taken over so many engine builds, even a single carb is less and less prominent. Getting a multi-carb set up be it on a BB or a SB engine can be a bit problematic to dial in but really, how often have you seen them at your local car show? Sometimes it's nice to step out of the box and venture forth. I'm running a SBC 283 with dual fours in my 57 Chevy 2 dr sedan and get a LOT of comments about it both in person and on a couple Tri-five boards I am on. Totally old school but then being almost 72 years young so am I, LOL.
Some what local to me board member Elliot949 has a really sweet 67 short bed , 327 with a Tri-power set up under the hood. When was the last time you EVER seen a 67-72 pickup with a Tri-power? Agree with Grumpy, "Smiles per Gallon" sometimes means more to me than miles per gallon.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#17 |
Well this might be a hole lotta fun at a car show . :lol
https://www.summitracing.com/parts/ofy-3924
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-03-2020 at 12:29 PM. |
#18 | |
But I agree with you. The classic small block with a carb (or carbs) is still a great setup. I put an L31 in my Blazer, but chose to go with HEI and a Quadrajet. Where Custom10nut said he plans to use it for a show car, I can't see any reason not to do it.
#19 |
Wow Grumpy, thats awesome! The fuel plumbing would need to be like artwork, love to see it hooked up and running on something...
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors ![]() |
#20 |
Not to hard to set up multible carbs. Hardest part is syncing them but it's just like doing a motorcycle. Also my AMX has dual Carter competition 625 cm 4bbls. Took a while to get the jets dialed in but it runs well. And yes peoples eyes light up seeing multi carb setups
#21 |
People with old Japanese motorcycles deal with it all the time. My KZ1000 - 1L 4 cylinder with 4 CV carbs.
Obviously a little different set up but it can be done! pain in the butt...yes
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#22 | |
Then you get the practicality side of the discussion. I’ve gotten a little more practical in my older age I guess. BTW, as a kid in the early 80s, I had a 10 second, 2-4bbl 427/4spd powered Nova that I drove around from April to November (In Michigan). I worked on the Family Dairy farm so most of my driving was by choice and Not necessity. Like I said, part of me can’t seem to let that go. Grump, the guy want $750 for it, with all the linkages and fuel lines, but the carbs need to be rebuilt. ![]() |
#23 | |
#24 | |
#25 |
