Old member
What have you guy's used for the rear dually wheels for putting air in them? I had to take my simulators off to get to the valve stems. I want something that will work without taking them off the next time.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
The Older Generation
Re: Dually wheel air valves
I don't have a picture on my computer but mine are flexible rubber and they clip onto the edge of the cutout in the rim. Here are some flex ones on eBay. They come in different lengths and styles. https://www.ebay.com/itm/2-STEEL-DUA...-/281490252274 LockDoc
#3 | |
Old member
I was looking at the ones I posted but I may try a local shop next week on I-85 when I go over to the LKQ yard to look for some parts.
![]() Join Date: Mar 2003
Just use the short rubber valves and use a long solid air chuck with the angled foot on it. The less places to leak the better.
#5 | |
Old member
The problem is with the simulators on the wheels I can't reach them. The holes in the simulators are much smaller. The wheel opening is fine but I don't want to have to take them off every time to check the pressure.
#6 | |
In one of the openings in the center. LockDoc
I've used both the metal extenders and the flexible ones (anchored to a wheel hub on a 29,000 lb motor home). Both work OK. The flexible ones are a little easier in my opinion.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson 1972 K/5 Blazer CST 4WD 1963 Corvair Monza Spyder Turbo convertible 1995 Camaro Z/28 |
Old member
Yes after seeing this and looking the flexable ones look to be better.
YEHAM 2pcs Stainless Steel 7"/180mm Tyre Tire Valve Stem Extension Adaptors Car Truck Trailer RV Trailer Vehicle 100% Brand new and high quality Reliable and durable:Made of copper nut and 304 stainless steel braided flexible hose with an aluminum alloy clip to fix the adapter Fit for trucks, RVs, campers, trailers, or other heavy vehicles Universal Type, Work With Tire Valve Directly, Have A Clamp / Fastener To Work Directly with Dual Wheel. Easy Work. Length: approx.180 mm. 7" long ![]()
Seems like those extras would impact the balance.
I just pop the caps off but I don't check mine that often so it's never been a concern.
#10 | |
Old member
![]() Join Date: Feb 2003
Thanks for this info. I have been thinking about something like this myself.
Keep them close to the hub. There's much less impact on the balance that way.
#13 | |
Old member
| Bookmarks |
