Starter issue
Well put anew starter in last week. Last one just clunked no spin or engagement of the bendix. The old starter had a few shims on the outside bolt to close the gap between the shaft and flexplate . I installed the rebuilt one it's a delco core had to shim outside bolt again to get the 1/8th gap. Everything was good truck started nicely . Wife went to move it today and it was grinding and kicking back on the starter. Shims still in and bolts still tight but I have a large gap again. I had even put in new starter bolts dont see how the starter could move. Not much I could do with my hand like this but I did add another shim to the outside bolt sounded much better and it started.
Anyone else experience this with a rebuilt? It's an autozone lifetime rebuilt in Mexico. Since the old starter was shimed the same way I'm thinking I may need to take down the pad on the cone a little at a time till it's at least close to use small shim
Re: Starter issue
Sometimes with a new or different starter you need to add more support.
Like a starter brace. Info here. http://67-72chevytrucks.com/vboard/s...d.php?t=492532 |
#3 | |
Re: Starter issue
Re: Starter issue
Here’s my .02.
Don’t bother with the “Rebuilts”, because you’ll only get mor and more frustrated, as it’ll work fine for the first few times them start acting up. I put “new” starters in my truck about every 3-4 months because they would start acting up, like the bedix wasn’t fully engaging, causing that go-awful grinding noise. Just get the New AC Delco starter and be done with it. In addition, it has the best warranty. Another thing I did was wrap the starter with a insulation blanket to prevent the Heat Soak from the Headers (common problem). Since I did this three years ago, I haven’t had any more issues. |
Re: Starter issue
I used to have the worst luck with AutoZone rebuilt starters and alternators. Seems like I was replacing them 2 to 3 times a year.
I found a local shop that rebuilds starters and alternators. I took them one of each and had them rebuilt. I haven't had any more issues with them since then and it has been close to 15 years now since having them rebuilt. |
Re: Starter issue
the new style high torque starters is what I've switched to using. they crank over faster, weigh a lot less, a lot smaller in diameter for clearance of headers, are comparable in price to the old style gm starters. several threads on here about them.
At the body shop.
Re: Starter issue
X2 on a mini gm starter usually $100 ish
" That didnt make it any newer " " Dont antique the equipment " |
![]() Join Date: Nov 2018
Re: Starter issue
Yep these are a win win in all departments in my opinion.
#9 | |
Re: Starter issue
One and done RRM
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
Re: Starter issue
My son had a starter that was wondering around like yours is. One day it was fine, the next it would sound awful. Finally took it off and hit the mating surface with a sanding disc on a grinder. Kinda roughed it up a bit, seemed to fix it. Haven't had a problem yet.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Starter issue
X4 on the GM mini starter.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
laying low
![]() Join Date: Mar 2001
Re: Starter issue
I've got an 88 truck 350 with the old style starter. What application do I ask for the get the GM mini starter to work on mine?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#13 |
Re: Starter issue
I usually ask for a 96 suburban 5.7. You also need the new bolts to go with it.
#14 |
laying low
Re: Starter issue
Thanks Dale.
#15 |
Re: Starter issue
you can find them on e-bay cheapest. you'll need to order the bolt pattern that matches your old starter. if I remember correctly it only used one of the two small wires on the solenoid, I just taped the extra up so it wouldn't short out and still be there if you ever had to switch back to the old style starter.
#16 |
Re: Starter issue
For staggered mount starters with 168 tooth flywheel and 11 tooth starter pinion, use for example a 2003 chevy 3500 8.1L (O’Reilly’s # 712884A) for straight mount with 153 tooth flywheel and 9 tooth starter pinion, use for example a 1995 Corvette 5.7L (O’Reilly’s # 612671A). They are both Nippon-Denso style mini-starters, easy to get over the counter, and last forever, most with a lifetime warranty. In the mid 80’s GM changed the starter bolt hole diameter from standard to metric. The standard bolt will not hold a metric starter in place for very long, especially a high torque starter. To use newer starters and with older blocks you need to have starter bolts with knurled 10mm shanks and 3/8s thread. Delco P/N 6449 - offset bolt pattern, used mostly on SUV and truck blocks, for 14 inch 168 tooth flywheels. Delco P/N 6442 - straight bolt pattern, used mostly on cars blocks, for 12 3/4 inch 153 tooth flywheels.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#17 |
laying low
Re: Starter issue
Good info Lee. Thanks
#18 | |
Re: Starter issue
![]() Quote:
#19 |
Re: Starter issue
Have dbelectronics mini on my 496 Chevelle never a problem but then again the 396 had an autozone cheapy for a couple of years . I'll most likely go with a new gm one
#20 |
Re: Starter issue
Put in a new DBelectric high torque mini . No shims and it’s dead nuts on . Little louder than stock but no more grinding . Going to return the rebuilt tomorrow it’s not even dirty
#21 |
Re: Starter issue
Awhile back I read a lot of negative response about DB Electric on another thread about starters. My experience with them has been VERY GOOD. I have their little starters on both my trucks, 1 SB, 1 BB & my B&S Vanguard powered golf cart. My Son has one of their starters in his K3500 6.5 diesel. I had problems with the frankenstein golf cart's starter, my fault, not their product. DB was very helpful. Free fast shipping & CHEAP . My only concern is where the products are manufactured.. I'm not sure but guessing chineez.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! Last edited by RustyBucket; 01-10-2021 at 01:47 PM. Reason: typoo |
#22 |
Re: Starter issue
I have a one of their ht starters on my chevelle 496 never a problem . Only one that failed wasnt for high compression motors.
#23 | |
Re: Starter issue
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
#24 |
![]() Join Date: Aug 2019
Re: Starter issue
Which mimi starter and bolts do I need for a 68 327?
#25 |
Re: Starter issue
Following for 68 327 with TH400
