![]() Join Date: Jul 2015
Wiper question
Are these wipers mis-matched? Only one has the rotation adjuster.
1963 C20, small window, long bed 292, 4-speed |
![]() Join Date: Jan 2011
Re: Wiper question
One original and one replacement arm. Do the jeep wiper are swap. It really works good.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: Wiper question
But does it look good?
![]() ![]() ![]() Join Date: Jan 2018
Re: Wiper question
Here's how my Jeep wiper arms look.
My opinion with them is this: If you have chrome windshield trim, go with chrome wiper arms. If you have the standard gasket, go with the Jeep arms, if you care more about having functional wipers you can rely on and easily source when you need new blades, go with the Jeep arms. I removed the aftermarket "stock" arms that didn't work well above 60 ish mph to go with the Jeep arms. No issues now with wiping away water when I'm on the interstate going around 70 ish
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#5 | |
Re: Wiper question
64-66 CHEVY JUNKIE
Re: Wiper question
Just Swapped mine... Much more pressure applied to the Windshield when Driving in Rain...
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Wiper question
Wiper arms are 10.95 each at LMC - https://www.lmctruck.com/1960-66-che...per-and-washer
Truck Shop in Orange has similar prices.
Re: Wiper question
I would like to know also.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Re: Wiper question
https://67-72chevytrucks.com/vboard/...ht=jeep+wipers
Here's a good thread. You could paint the arms silver. |
Re: Wiper question
The thread linked by bigmoe is the one I used when I did mine. 87-96 XJ Cherokees are the Jeeps of choice. 97 and up Cherokees have a larger diameter post. You need to purchase 2 rear arms, but you only need to do the flip on one of those. None of the Cherokees had chrome wiper arms, so if you want that look, you'll have to either get them chromed or paint them to look that way
Re: Wiper question
I have been looking for the steel wiper arms and blades, and I think I found something I will be happy with; better than what I found at the Truck Shop. The wiper blade from the Truck Shop was too shiny, I wanted something that has that dull steel look, ike a satin finish.
The wiper arm is an ANCO 41-02; it is n adjustable length arm. The wiper blade is a TRICO 33-130 ( I picked this up on Amazon). Not sure if this is inof that has already been posted, just thought I would share.
Who Me?
Re: Wiper question
I had chrome aftermarket arms on mine and no adjustments.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#13 |
Re: Wiper question
Is there a left and right arm for these trucks?
#14 |
Re: Wiper question
My son bought replacement arms from either Brothers or his work. The passenger side does not seat well and does not wipe the window all the way. He has not taken the truck on the freeway that I am aware of, so I am not sure how that works. So, Jeep wipers are good? I will tell him, he will probably roll his eyes and tell me to shut up. LOL.
#15 |
Re: Wiper question
I still have to figure out which Jeep wiper arms to get. Is it the Jeep Cherokee? 1980’s?
#16 | |
Re: Wiper question
If you find the arms from a junkyard, make sure there's no corrosion around the tension spring mount next to the splined part of the arm. I had one from a junkyard like that, and it ended up breaking off on me during a rare, GA snow. I didn't have time to go to the junkyard to find another, so I ordered a new arm from RockAuto. It was the passenger side arm which is not the one that needs to be flipped, thankfully
#17 | |
Re: Wiper question
#18 |
Re: Wiper question
I used a Trico 14" blade that wasn't specific to any make or model. It was in the red Trico package. There's not really a specific part number to the blade itself. The main thing is making sure you get a blade with the correct mounting point for the arms.
#19 | |
Re: Wiper question
Is that called a pin-type mount?
#20 |
Re: Wiper question
I'm not sure what type mount it is called. I went into the local parts store and found a blade that matched
