Old 12-06-2020, 06:14 PM   #1
cericd
cericd's Avatar
URGENT: Front Drum to Disc Prop Valve and Parts Question
I'm in the process of doing a front drum to disc brake swap on my 1970 C/10. I am wanting to keep it looking like a stock 1971 disc/drum installation. I have the following parts so far.
A set of 5-lug GM 15" x 6" 4-nub steelies
For the front:
CPP 6370SWBK-5OE-S Drum to Disc Swap Kit (which includes)
- Classic Performance Products Stock Height Spindles
- Twelve-inch Standard Vented Rotors (5-lug)
- Calipers
- Dust Shields
- Bearings, Seals and Spindle Nuts
- Dust Caps and Banjo Bolts
- Standard Brake Hoses
A restored Delco-Moraine brake booster (with brackets and push rod)
For the back:
5-lug conversion axles
(need to get)
5-lug brake drum
new shoes
new wheel cylinders L & R
wheel studs (Dorman 610-298.1 - 1/2 x 20)?
I am trying to find a disc/drum prop valve that looks stock. I found one at inlinetube but the price is two-three times the cost of the style that looks like a block of brass. Also, what master cylinder should I get for a factory look considering I will be running a brake booster? I'd really like to source stuff locally if possible so I can get this wrapped up before the first of the year.
I have also read mention of a rubber boot that will be necessary since I am adding the booster to a non-booster truck. Is that correct?
What about my brake "idiot" light on the dash, will that still work once everything is hooked up?
I have also heard about the pinion shaft bolt breaking when doing a axle swap. Does anyone have the part number for a replacement? I can't seem to find that info online. I have the stock (wide) 1970 rear end.
Are there other parts I'm forgetting?
Here are the different prop valves. I'm looking for the factory cast iron style as shown in the first picture but $199 before shipping seems a bit steep. Wondering if there is another supplier. The one that came in the ECE kit came with looked like the cast iron one (but I know they're out of business now).
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 12-06-2020, 07:18 PM   #2
gmc684x4
Re: URGENT: Front Drum to Disc Prop Valve and Parts Question
Have you tried gmc pauls brothers or lmc ?
gmc684x4 is offline   Reply With Quote
Old 12-07-2020, 02:01 PM   #3
cericd
cericd's Avatar
Yes, I have. They don't have the prop valve I am looking for.
Chris
Old 12-12-2020, 12:11 PM   #4
68 P.O.S.
What's wrong with the one that came with the ECE kit?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-12-2020, 12:26 PM   #5
cericd
cericd's Avatar
Nothing, I assume. They went out of business before I could purchase their kit and now I’m trying to piece together a matching setup from other vendors and I’m having a difficult time finding a stock looking prop valve.
Chris
Old 12-12-2020, 12:31 PM   #6
gmc684x4
Does it have to be new you could look at square body trucks or g20 vans which have the same brake setup as a sqaure c10
