Old 12-07-2020, 11:34 AM   #1
Mackie
Mackie's Avatar
Quality H-Light switch for ‘63 C10 ?
The new aftermarket switch I installed about 10 yrs ago has failed.
The re-pop vendors have them for about $25 and NAPA has one, from the (once) respected name Echlin for $70
Can anyone justify the higher price?
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 12-07-2020, 12:12 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Quality H-Light switch for ‘63 C10 ?
I run a Ron Francis headlight switch in my builds. I think you can get them from Summit Racing for around $45.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-07-2020, 12:19 PM   #3
Mackie
Mackie's Avatar
Thanks, do they accept the OG harness plug ?
`63 C-10 Shortwide
T5
Old 12-07-2020, 07:42 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
I recently had to purchase a new headlight switch for my 63. I went with a Standard Motor Products one and ordered it from Amazon because the same part was about $40 more at the local parts store. It has worked great for the past 2 months that I've had it in. My old switch was hard to make it stop on the parking light circuit because the detents were not that great, but the new switch is real easy to stop in all 3 positions
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-08-2020, 11:52 AM   #5
vin63
vin63's Avatar
I believe they do. Give them a call.
Old 12-08-2020, 12:17 PM   #6
Mackie
Mackie's Avatar
Thanks guys, I went on-line Summit and found nothing from Ron Francis or the “make/model” OEM search that convinced me.
I have a Standard on the way from RockAuto.
`63 C-10 Shortwide
T5
Old 12-08-2020, 03:19 PM   #7
vin63
vin63's Avatar
https://www.summitracing.com/parts/rfw-hl03
Old 12-09-2020, 12:16 PM   #8
1966burb
1966burb's Avatar
I purchased a NEW Delco headlight switch only to find out it was imported junk. Later I found a NOS Delco one on eBay which was stamped made in USA which I installed.
1966burb is offline   Reply With Quote
Old 12-09-2020, 12:42 PM   #9
hairball
Morning all,
Just received my headlight switch for my 65 C10. It's a Suntex brand ( $14.95). It felt and looked cheaply made, and was faulty right out of the box. I went to my local NAPA store and got an Echlin ECH HL6554 switch ($22.99). The quality looked and felt much better and works great. Time will tell if it's a good one or not. Both these switches were made in Taiwan. I do plan on doing the headlight relay mod in the future.
hairball is offline   Reply With Quote
Old 12-09-2020, 01:53 PM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by hairball View Post
Morning all,
What headlight mod is that?
Old 12-09-2020, 04:56 PM   #11
hairball
I use 2 relays one for low beam and one for high. When doing this the only job of the headlight and dimmer switches is to supple a small amount of current to energize the relay. The energized relay sends full voltage from the battery straight to the headlamp. It's not unusual to have a voltage loss through the switches, multiple connectors and lots of wiring especially with older wiring.
Old 12-09-2020, 05:30 PM   #12
The Rocknrod
Moderator
Oh that one. I have installed relays for my headlights as well. Your right, it's a great idea.
Old 12-10-2020, 01:50 AM   #13
franken
I wouldn't expect better quality than NAPA and the relay bits are a nonsequiter...
franken is offline   Reply With Quote
Old 12-11-2020, 02:52 PM   #14
cgrocen
Same headlight switch fits 1957-1963 Chevrolet cars. Maybe hitting the junkyards if you have any around your area might turn up an original Delco switch. They also fit some Buicks as well. Here is a list of vehicles that use the same switch:
BUICK ELECTRA 1959-1963
BUICK ESTATE WAGON 1960-1962
BUICK INVICTA 1959-1963
BUICK LESABRE 1959-1963
BUICK RIVIERA 1963
BUICK SKYLARK 1961-1963
BUICK SPECIAL 1961-1963
BUICK WILDCAT 1962-1963
CHEVROLET BEL AIR 1957-1963
CHEVROLET BISCAYNE 1958-1963
CHEVROLET C10 PANEL 1962-1963
CHEVROLET C10 PICKUP 1960-1963
CHEVROLET C20 PICKUP 1960-1964
CHEVROLET C30 PICKUP 1960-1964
CHEVROLET CHEVY II 1962-1963
CHEVROLET CORVAIR 1960-1963
CHEVROLET CORVETTE 1957-1963
CHEVROLET DEL RAY 1958
CHEVROLET EL CAMINO 1959-1960
CHEVROLET IMPALA 1958-1963
CHEVROLET K10 PICKUP 1960-1964
CHEVROLET K20 PICKUP 1960-1964
CHEVROLET P10 SERIES 1960-1963
CHEVROLET P20 SERIES 1960-1963
CHEVROLET P30 SERIES 1960-1963
GMC 1000 SERIES 1961-1963
GMC 1500 SERIES 1961-1963
GMC 2500 SERIES 1961-1963
GMC 3000 1961-1963
GMC 3500 1961-1963
GMC G1000 SERIES 1963
GMC PB1000 SERIES 1961-1963
GMC PB1500 SERIES 1963
GMC PB2500 SERIES 1963
GMC SUBURBAN 1960-1963
GMC TRUCK 1960
GMC V3000 FORWARD CONTROL 1961-1962
Info from Rock Auto.
cgrocen is offline   Reply With Quote
