Old 12-12-2020, 07:26 PM   #1
71K5Randy
71K5Randy's Avatar
WTB door cut for patch
Looking to buy a passenger side door cut that’s rust free, to repair a C10 door I have that someone started to modify the front lower corner to fit a C60.
Thanks!
Randy
71 K5 CST Blazer 350
70 Suburban 350
69 Olds 442 425
68 Camaro RS 327
66 Chevelle SS 396
Members I have met: 62cdan, 60case, daddymoo2, aotte1, 70shortfleet, countr, Cowboy#40, chevy71super, davischevy
71K5Randy is offline   Reply With Quote
Old 12-12-2020, 09:36 PM   #2
Clatterville trolley
Clatterville trolley's Avatar
Re: WTB door cut for patch
Thanks!
Randy
Randy - I am currently working on one of my doors because of rust through in that same area - and many other areas
I plan to make that piece out of new 18 gauge metal.
If you can wait a little bit and would send me a piece of paper showing the size piece you need - or describe it with measurements - I could make you one when I make mine for $15 and shipping to you.
You didn't indicate if you only needed the outer skin part or if you needed the inner part also??
PayPal 1windyridgeboy@gmail.com
Clatterville trolley is offline   Reply With Quote
Old 12-12-2020, 09:39 PM   #3
Here are a few photos of what I am dealing with - probably should have gotten a different door, but hey what kind of a challenge would that have been!!
Old 12-12-2020, 11:53 PM   #4
71K5Randy
71K5Randy's Avatar
I’m in need of both inner and outer. The inner would be more work to fab since it has been formed to add strength. Thanks for the offer, I’ll see if anyone turns up with any factory metal first.
70 Suburban 350
69 Olds 442 425
68 Camaro RS 327
66 Chevelle SS 396
Old 12-13-2020, 12:27 AM   #5
franken
This is just a comment, let's no get into a gauge war here...
I'm always curious why people use 18 gauge when the original metal is more like 22 gauge. I get responses that are something like it's the industry standard, etc. but you can lay bits of metal next to each other and see 18 is far far thicker.
Carbon Steel Gauge Chart
Gauge
Number Inches MM
7 .1793 4.554
8 .1644 4.175
9 .1495 3.797
10 .1345 3.416
11 .1196 3.038
12 .1046 2.656
14 .0747 1.897
16 .0598 1.518
18 .0478 1.214
20 .0359 .911
22 .0299 .759
24 .0239 .607
26 .0179 .454
28 .0149 .378
franken is online now   Reply With Quote
Old 12-13-2020, 01:37 AM   #6
franken
Look at the difference in numbers. 18 is almost is almost double the thickness of 22. As I mentioned, side by side, the difference is vast.
18 .0478 1.214
22 .0299 .759
Old 01-24-2021, 03:35 PM   #7
71K5Randy
71K5Randy's Avatar
Ttt
70 Suburban 350
69 Olds 442 425
68 Camaro RS 327
66 Chevelle SS 396
Old 01-24-2021, 04:43 PM   #8
Tmend
Tmend's Avatar
Pm sent
Some progress is better then no progress
Tmend is offline   Reply With Quote
