700r4 vacuum hose and 2 wires for lock-up?
Hey guys, i just got my 700r4 tranny fixed (we took it out of the truck and brought it to a shop). It's an early model (82-84) that i had in my 76. So when installing it back into my 76, there's a vacuum hose and 2 wires for lock-up...not sure where they go correctly? Any info would be appreciated. Thanks.
1979 GMC Sierra 3/4 ton Camper Special 1976 Chevy Cheyenne 3/4 ton |
Just here to tinker
Re: 700r4 vacuum hose and 2 wires for lock-up?
I believe only the t400 had vacuum? 700R4 should have a TV cable.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
No vacuum hose on any of my 700r4's There is a kit for the lockup.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
![]() Join Date: Mar 2003
Are you sure you don't have a T350C
Moderator
![]() Join Date: Oct 2008
TH700R4 & 4L60 have TV cables not vacuum modulators.
If you have a hose on a TH700R4 transmission it's a vent.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
![]() Join Date: Apr 2009
This is the only thing I've ever seen controlling anything on a 700R4 , It has a single vacuum line and a two wire harness that controls torque convertor lockup (TCC).
Desert |
All 700R4's do have one electrical plug located on the left side of the trans that I know of which is for converter lockup. While the trans doesn't have a vacuum modulator like the 350's and 400's it does have a vacuum switch to unlock the converter under load which is located by the brake booster and looks similar to the one pictured by desert. The one he showed though is actually a vacuum tip-in switch for the later ESC distributors. I attached a wiring diagram from a factory manual (Note RPO MD8 is for a 700R4) I believe there is a non-egr one that exists too but is very similar. Hope that helps!
Found a picture online, this is the vacuum switch and plug for the TCC
| Bookmarks |
