Old 12-13-2020, 10:24 PM   #1
a32axo
Flip kit questions.
I have this flip kit on my truck, I’m not sure if it sits right? Do I need a new flip kit or is this one not installed right?
a32axo is offline   Reply With Quote
Old 12-14-2020, 01:24 AM   #2
xs-cash
Re: Flip kit questions.
Looks homemade
xs-cash is offline   Reply With Quote
Old 12-14-2020, 02:48 AM   #3
RustyPile
RustyPile's Avatar
It does look home made.. I'd like to see a picture of the pinion to driveshaft angle...
RustyPile is offline   Reply With Quote
Old 12-14-2020, 10:46 AM   #4
SCOTI
SCOTI's Avatar
I agree that looks like a home-made part. The 'uprights' on aftermarket brackets should make contact & seat in place @ the original perch flange/pad.
Check both sides & compare.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-14-2020, 01:57 PM   #5
a32axo
Thank you. It’s is home Made I’m thinking. Now the question is when I purchase a legit flip kit will it higher or lower my truck even more?
Old 12-14-2020, 02:11 PM   #6
SCOTI
SCOTI's Avatar
Looking @ the side profile of the upright & comparing to most 'flip kit' brackets, that one is taller under the axle tube area which will lower the truck more. So swapping a legit flip bracket from say Belltech will probably raise the truck slightly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-14-2020, 06:00 PM   #7
a32axo
Cool thank u. I do want to be a little higher. Is bell tech like djm flip kit? Does it make a difference in which one to get? Also would adding a leaf to the pack make me higher or lower?
Old 12-14-2020, 06:22 PM   #8
SCOTI
SCOTI's Avatar
Belltech is definitely higher quality vs. DJM.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-14-2020, 09:01 PM   #9
a32axo
Couldn’t find one for a 1970 gmc
Old 12-14-2020, 09:17 PM   #10
xs-cash
Any flip kit for 73 to 87 will work on a 67 to 72 rear , the difference is in the c notch , frame is slightly different
Old 12-14-2020, 09:44 PM   #11
Mike C
Mike C's Avatar
The 67-72 flip is designed for 2 1/4" leaf springs and the 73 and up for 2 1/2" springs. If you want to hug the spring with the u-bolts you need the 67-72 setup.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-14-2020, 09:48 PM   #12
a32axo
Got it I didn’t think the 1973 would of worked.
