Old 12-17-2003, 10:13 PM   #1
oleblue72
No, U Da Man!
oleblue72's Avatar
These heads ok?
Oleblue is not running very well.( acts like a burnt valve) I couldn't figure out the problem, so I took it to a shop and they said the valve guides were bad. I want to change the 487 heads and install a better cam. My Dad has a set of heads, He will give me. Casting numbers are 10110810, Mortec shows 91+up Gen.1 65cc chambers. You folks know anything bout'em? bolt right up?
my block is original. Thanks
(sold ole blue 1972)
1997 Dodge 1500 5.9L
1996 Saturn SL2 1.9L
2002 Mitsubishi Montero 3.0L
2005 Ford Escape 3.0L
1967 Olds Vista Cruiser 330-320HP
oleblue72 is offline   Reply With Quote
Old 12-17-2003, 11:51 PM   #2
68c10owner
68c10owner's Avatar
you don`t want those heads. they will bolt up but you either have to get a new intake cuz the 2 center bolts are straight up and down, or modify your intake. a good set of hears are 96 up vortec truck heads. you can find them fairly cheap but again, you`ll need a vortec intake which edelbrock sells.
Anthony
68c10owner is offline   Reply With Quote
Old 12-18-2003, 02:22 AM   #3
jhow66
jhow66's Avatar
Also your compression would go way up causing you to have to use higher octane gas.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-18-2003, 03:57 AM   #4
73stepside
73stepside's Avatar
you would also need center bolt valve covers
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 12-18-2003, 02:22 PM   #5
oleblue72
No, U Da Man!
oleblue72's Avatar
Thanks for the input. Think I'll keep looking for something that will match my exsisting components. Might even have the 487's re-worked. Thanks again!
