Does anyone have an Expanded Picture of a Tilt Steering Column?
I put a Tilt column in my truck a few years back. I bought it used, of course.
It came to me partially disassembled, as the shift lever was off to ship it to me. I bought a new shift lever, because the one it came with was cut down and modified, Badly. Anyway, when put the new lever in I damaged the detent spring inside at the base. Another board member sent me another spring, which helped some, but I think it still doesn’t have the spring pressure that it should. Has anyone ever had this issue? Is there a source to get this spring that I’m talking about? Is there a special technique to properly remove and install this spring, without damaging it? |
Re: Does anyone have an Expanded Picture of a Tilt Steering Column?
It’s hard to believe nobody has any insight or input on this
Patience grass hopper some people are eating dinner.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
Best I can find that the moment.
![]() Join Date: May 2010
Here are tilt pics from an old thread. (http://67-72chevytrucks.com/vboard/s...d.php?t=157328)
Jim |
The last pic. Google GM part number 7812853 and you'll find numerous sources for the spring I think you are looking for. Apparently GM still has springs.
http://67-72chevytrucks.com/vboard/s...d.php?t=627718
Jim Last edited by FirstOwner69; 12-15-2020 at 01:55 AM. |
#7 | |
This is what I was looking for. Now I know that I’m missing the retainer button that sits on top of the spring. When I put the replacement spring in, I know I didn’t take one out or put one (retainer button) in. Now I search for a source for these parts. Any Leads out there? |
![]() Join Date: Aug 2004
The shifter lever spring has no retainer, it sits in the bore with a little tension. I’ve removed them with a pocket screwdriver and needle nose pliers. Reinstall with the same.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-16-2020 at 10:58 AM. |
That silver button that says “use a Phillips to remove” retains the tilt spring, it has a not-quite 1/4” hole in the end.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
