Old 12-14-2020, 11:21 AM   #1
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Headers that fit?
I'm looking for recommendations for headers that actually fit these trucks. I don't trust manufacturers fitment claims. I bought a truck that a PO had installed headers on & to accomplish this he had notched the frame & bent the zbar to sorta clear. When I removed them & looked up the part number on them the manufacturer says they fit. That's not my idea of fitment.
So that being said, I have a 67 with a 283 in the forward mount position & a manual transmission. I want to know what full length headers you guys have used with no fitment problems?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 12-14-2020, 11:24 AM   #2
Redneck Rydes
Redneck Rydes's Avatar
Re: Headers that fit?
In my years of building vehicles,I have never found a set of headers fit without some tweaking,I have always used Headman Headers,usually fit the best,with minor tweaking
Redneck Rydes is offline   Reply With Quote
Old 12-14-2020, 11:32 AM   #3
toolboxchev
First I would like to say that your have pointed out the reason why I have stayed with stock manifolds. Your not alone. Do a search on here and most likely will find some good opinions about manufactures and model numbers.
Finding headers that fit without issue is pretty much an oxymoron. Take a close look on peoples builds.
toolboxchev is offline   Reply With Quote
Old 12-14-2020, 11:35 AM   #4
tim_mc
tim_mc's Avatar
My Summit headers fit with no issues at all. P/N SUM-G9006-SS.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 12-14-2020, 11:59 AM   #5
SIXTY9
Look at KOOKS Headers. Call and talk to Tyler Sandahi, 704-768-2288 ext:228. He is very good. mine fit great.
SIXTY9 is offline   Reply With Quote
Old 12-14-2020, 12:14 PM   #6
pjmoreland
pjmoreland's Avatar
My first C10 was a 67. I installed some cheap headers on it, and they fit without notching. I don't remember the brand, but i think i bought them from JCWhitney in 1996. I installed Hooker headers on it a few years later and had to notch the frame. The 67 frame has less room for headers than 68-72 frames. I suspect manufacturers don't take this into account when designing headers. My 68 came from the PO with headers already installed, and no notching was required. I don't know the brand, but the tubes are smaller than my old Hooker headers.
pjmoreland is online now   Reply With Quote
Old 12-14-2020, 12:55 PM   #7
gmc684x4
I have had no issues with headman on my 68 k10 and no issues on my dads 72 k10 with hooker headers
Both are 4 speed trucks
I think engine placement also plays an issue as a rwd places a v8 further forword
gmc684x4 is offline   Reply With Quote
Old 12-14-2020, 03:32 PM   #8
tim_mc
tim_mc's Avatar
Good point..my V8 is in the I6/4x4 V8 position further back.
Old 12-14-2020, 04:22 PM   #9
pjmoreland
pjmoreland's Avatar
Here's a photo of the factory notch on my '68. My '67 did not have these factory notches.
Old 12-14-2020, 05:56 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Although these are more money than most I've read that they fit with no issues.
https://www.sandersonheaders.com
https://pertronixbrands.com/pages/th...-dougs-headers
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-14-2020, 11:23 PM   #11
tj1970cst
I used jegs brand headers. Fit well except I heated 1 tube and whacked a dent in it on passenger side. Besides that, I actually tried no less than 4 sets and none came close to fitting. It was ridiculous.
tj1970cst is offline   Reply With Quote
Old 12-15-2020, 12:42 PM   #12
Myself
Why is there no sticky with a definitive list of known headers that fit??
Sort of like a known wheel fitment, offset, and drop thread on most forums.
Myself is offline   Reply With Quote
Old 12-19-2020, 10:33 AM   #13
Stover93
Sanderson does have some that fit great. I bought the mid-length ones. Can’t remember the exact model number. I do recall them being very helpful when I called though.
Stover93 is offline   Reply With Quote
Old 12-19-2020, 12:48 PM   #14
REDROCKER652002
My son bought a set of Hedman short headers, not sure what the short part meant other than maybe the length of the tubes coming down the side. I had to just grind a small amount of frame, I mean less than an eight of an inch, off to get them to fit. Other than that and a poorly bent brake line that needed a bit of adjustment, they fit pretty well. They sound good too. I will say the bolts to get them to tighten were a pain as you have to get them all started, then tighten each one a small amount as you go. If you tighten one or two all the way then the others hit into the pipe and won't allow you to thread them. Not a big deal, but when you are bent over and have sausage fingers it is a bit of a drag. LOL
REDROCKER652002 is offline   Reply With Quote
Old 12-23-2020, 05:17 AM   #15
ChevyRacefan
ChevyRacefan's Avatar
Remember tube size plays allot into if a set slides in and bolts up, or if you need to tweak them a little.
Small tube headers that are a slide in, bolt on are not going to gain you anything over a set of 2.5" exit corvette ram horns . Other than that pinging noise of the exhaust in the header tubes and the bolts backing off &gasket leak headaches that many headers suffer from.
speedway motors sell the repop vette ram horns, iirc for 120 a set.
ChevyRacefan is offline   Reply With Quote
