Old 12-14-2020, 08:35 PM   #1
saddletramp
72 Headlight,s
Evening Guys Im baffled ive fixed my Bezel lights now my headlights have some gremlins i turn my headlights on 2 minutes later they blink a few times then go out ive installed my grounds 2 on the firewall to the valve covers, 2 core support to the inner fenders, frame to the body 4 locations, 3 different high bean switches, new headlight switch which needed to be changed, ive searched this site looking at threads can someone give me some input on what to do next Thanks Saddletramp
saddletramp is offline   Reply With Quote
Old 12-14-2020, 10:04 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 Headlight,s
I would check the dimmer switch in the floor first. Check it with a volt meter and operate it several times to see if it's working good. If that all checks out then look at the connection on drivers side back side of head light. It supplies 12 volts to both head lights. Make sure you didn't pull it loose while working on them. One thing to look for is the wire connection's in the plastic are all tight. If you unplug the light check the connections by pulling on them to make sure they don't come out of the housing.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-15-2020, 10:00 AM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 72 Headlight,s
Also check the headlight switch. The switch has a internal breaker that will shut the lights off until it cools off.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-15-2020, 02:33 PM   #4
72bowtiestepper
Re: 72 Headlight,s
Make sure the headlight switch is grounded to the dash panel also...can cause all kinds of strange problems if it does not have a good ground.
72bowtiestepper is offline   Reply With Quote
Old 12-15-2020, 03:07 PM   #5
saddletramp
Re: 72 Headlight,s
Thanks Guy,s for the input on the headlight gremlins appreciate ya Saddletramp
Old 12-15-2020, 07:20 PM   #6
72c20customcamper
72c20customcamper's Avatar
Re: 72 Headlight,s
Stock lamps ? I've had a few vehicles that did the same thing with halogen headlamps . Breaker was a little weak .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
