Old 12-14-2020, 10:07 PM   #1
tj1970cst
Tach/vac cluster-counterpart
I recently used the vacuum gauge kit from truck shop to add a gauge to my truck that had factory tach and gauge package.
The text seems to be crooked so there is no room above the oil pressure and 1/4" above the battery. Also noticed that the green paint is on the wrong side of the clear lens, so the light from the bulbs doesn't come through to illuminate the numbers on the speedo and tach.
I have been emailing them. So far they say it might take adjustments. I do not see how anything could be adjusted, since all the plastic and tin pieces have interlocking pegs and stuff.
Anyone know what I should do to make this look/work better?
Please excuse the elf in the picture. It's a good picture of the cluster, just happened to have the elf posing.
tj1970cst is offline   Reply With Quote
Old 12-16-2020, 08:44 AM   #2
OL SKOOL
OL SKOOL's Avatar
Re: Tach/vac cluster-orange county truck shop counterpart
I purchased the 2 gauges lens and tins from the same place. They have been sitting in a box for about two years patiently waiting their turn. I never noticed but mine seem to be the same. I don't remember about the green on the lens been together a couple of years. Not the best photographer but i took these this morning. Because i was curious when i saw your post. That is the problem with most aftermarket parts. Either a little off or WAY off. The good news you will probably the only one to notice it, oh and now me!
OL SKOOL is offline   Reply With Quote
Old 12-16-2020, 11:05 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Tach/vac cluster-orange county truck shop counterpart
That little bit could be from each cluster being a tick off! These trucks didn't have near the precision they do now. The cluster they used to make the parts more than likely fits perfect.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-17-2020, 12:56 AM   #4
tj1970cst
Thanks Andy! If anyone had some experience, I figured you would.
Old 01-13-2021, 03:47 AM   #5
tj1970cst
Glad I could ruin it for you as well. 😂
