Old 12-15-2020, 08:06 PM   #1
manuelv72
serpentine setup
Hello all, I recently installed a serpentine setup off a 98 Tahoe in my 72 with a pre-Vortec 5.7. my question for you all who have done this mod is as follows, #1- Im using the 98 water pump, how do I hook the heater core hoses being that the water pump has 2 inlet/outlet lines coming out of it, or is there an alternative pump I can use?
#2 I am also using the cs130d alternator, how did you hook that up? a wiring diagram would be awesome.
I would really appreciate any info, thanks
manuelv72 is offline   Reply With Quote
Old 12-15-2020, 09:08 PM   #2
HotWheelsFan
HotWheelsFan's Avatar
Re: serpentine setup
As far as I know heater hoses that connect to water pump are return hoses to the cooling system. Hot water to the heater core comes from the intake manifold, same area as where the thermostat is. Hot water is then run through the heater core and returned to the engine. My truck has a return line, from the heater core, on the radiator it-self. Located just below the upper radiator hose.
So, you may have a place to connect it to on the radiator or water pump...
Hope this helps a bit.
Bob
HotWheelsFan is offline   Reply With Quote
Old 12-15-2020, 09:13 PM   #3
gmc684x4
you can use a pre vortec pump from say a 91 c1500 with a 5.7
if you have upgraded to Si alternator you can use ec82 adapter plug with resistor for your cs130 upgrade
Si is a square body internally regulated alternator
https://www.napaonline.com/en/p/ECHEC82
gmc684x4 is offline   Reply With Quote
Old 12-15-2020, 09:17 PM   #4
gmc684x4
You could remove the bypass outlet use pipe thread tsp and install pipe plug in its place
Old 12-15-2020, 09:42 PM   #5
manuelv72
Bob
so both lines on pump are returns? could i run 1 line from htr core to pump & t other to radiator?
Old 12-15-2020, 09:48 PM   #6
manuelv72
thanks for the info on pump, will look into that. as for alternator, in going from stock delco dn10 to the 98 cs130D so trying to figure out wiring for that model
Old 12-15-2020, 09:52 PM   #7
manuelv72
Thanks, ill look into that.
Old 12-15-2020, 10:09 PM   #8
Smitty
Smitty's Avatar
Look up M&H wiring. I think they are in Santa Fe Springs, Ca. They may well have a pig tail to adapt the current harness to the new alternator. Relatively cheap and easy to utilize.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 12-17-2020, 11:52 AM   #9
MARKDTN
Delco 8078 is the CS to SI pigtail with gauges
Delco 8077 is the CS to SI pigtail with light
You will have to change some wires first.
https://www.novaresource.org/alternator.htm
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-17-2020, 06:39 PM   #10
manuelv72
sweet, thanks for the info. will look into them
Old 12-17-2020, 06:40 PM   #11
manuelv72
Thumbs up Re: serpentine setup
thank you for the link, will look into it
