Old 12-16-2020, 02:09 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Nissan mirror
I had installed a GM rear view mirror several years ago with the Compass & temperature readings in it and the home-link buttons in the ash tray for opening the garage door. It worked but not like I wanted it to.
Well I have since upgraded to a Nissan mirror that has everything in the mirror.
I can open the garage door, check the temperature and see what direction I'm going all at my finger tips.
The new Nissan mirror requires a different temperature probe though out front.
I mounted it over to the side this time.
The link is when I did the first install.
http://67-72chevytrucks.com/vboard/s...=432526&page=2
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-17-2020, 08:04 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Nissan mirror
After doing a bunch of reading and searching on the net today I decided to try it.
I took one of the GM Gentx-177 mirrors a part today to see what they look like inside. I also changed the color of the temperature & compass read out.
What color you ask.... RED!
I will work on the Nissan mirror tomorrow to swap it out to red also.
Old 12-18-2020, 12:17 PM   #3
lutronjim
Re: Nissan mirror
Andy4639
Could you provide model and year Nissan.
Also if it is a windshield mount mirror.
lutronjim is offline   Reply With Quote
Old 12-18-2020, 01:06 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Nissan mirror
Originally Posted by lutronjim View Post
Andy4639
I don't know the year. It's a Nissan rogue. Sorry I don't know these vehicles. It's a newer model though.
Yes it's a windshield mount.
Old 12-19-2020, 05:08 PM   #5
Andy4639
Old member
Andy4639's Avatar
I swapped the Nissan home-link mirror out today in my 71. I made the read out to RED! What did you expect.
I also mated the factory 71 mount to the new mirror. It's not perfect but it does work. I'd like to find a shop to try and make a few mounts for them and have them as a option.
Old 12-22-2020, 12:58 AM   #6
Andy4639
Old member
Andy4639's Avatar
Re: Nissan mirror
I made a smaller adapter for the truck mirror. This will work I think.
Old 12-22-2020, 12:44 PM   #7
saon
Re: Nissan mirror
so the gm sensor doesnt work with the nissan mirror? needs nissan sensor?
i grabbed a couple nissan mirrors a few months ago because they all were in 1 package with compass, temp and homelink but havent installed them yet. i grabbed a couple gm sensors thinking they would work.
also, how did you change the color display?
also i think mine came from 2008 nissan suv rogue or frontier i cant remember exactly
saon is offline   Reply With Quote
Old 12-22-2020, 01:34 PM   #8
Andy4639
Old member
Andy4639's Avatar
Correct you have to get the Nissan probes for the temperature to read right. Each manufacture has it's own probe from what I have read and saw in the yard. The GM probes will read but they will be way off. I'm not a expert on this but I'm learning. I've been reading and experimenting on mine. To change the readout color you have to take the mirror a part and peel the C&T cover off, then I use the red tail light film from O-Reillys to make it red. I tried using the amber but it didn't work as good. Look at the pictures above and you can see the film that you just peel off of the mirror read out. You can leave it off and it's much brighter also.
Here is a video I just did on one testing it. It heated up and then cooled back down.
https://www.youtube.com/watch?v=ICi0JdxjXsQ
I'm also working on a mirror to go in my 64 SS Impala if I could find one with everything inside the mirror. I don't want the compass stuff on the windshield mount. I want a GenTX 453 mirror it has everything inside the mirror.
Old 12-22-2020, 02:39 PM   #9
Andy4639
Old member
Andy4639's Avatar
Here is the 10 pin connector it works with both mirrors. Gen 313 & Gen 453. The wire colors maybe different but the wires are doing the same functions.
The Gen 313 mirror has the compass on the window mount like a GM mirror.
The Gen 453 has everything inside the mirror housing. Makes for much cleaner look.
Plus I can make a mount for it to use the factory mirror mounts in about any vehicle also. The 4th picture is in my 64 SS Impala. The last picture is a factory 71 C-10 mount.
Old 12-22-2020, 03:02 PM   #10
BigBird05
Re: Nissan mirror
I love the idea of the GenTX 453 mirror. What is it out of and what years? I will go junk yarding tomorrow and get me one for Christmas.
BigBird05 is offline   Reply With Quote
Old 12-22-2020, 05:40 PM   #11
Andy4639
Old member
Andy4639's Avatar
Nissan Rogue.
