one piece floor pan 1961
I am planning on starting on my grandfathers truck hopefully around the first of summer. The truck is pretty rough and there are several holes in the floor. I am thinking it might be easier and cleaner finished product to use a one piece floor. Issue is the frame is rusted out, I have a 63-66 frame and I am getting another 60-62 frame in the next week. Not sure which direction we are going with the truck yet, stock or not. If i decide to "hotrod" the truck and make it a driver I'll probably use the 63-66 frame. I know the cab mounting is different so my question is can I use a 63-66 one piece floor on my 61 to make it easier to bolt the cab to the frame? Thanks
![]() ![]() ![]() Join Date: Jan 2018
Re: one piece floor pan 1961
As far as I know, the only difference in the floors is where the cab mount bolt goes through. The floor patch panels that do not have the cab mount area in them are listed as 60-66
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
