12-18-2020, 11:54 PM | #1 |
Sm465 swap using parts out of a i6 truck?
I decided to go a different route with my 1969 gmc 1500 and I will be swapping my 2004r for a sm 465 as the first part of a 4wd conversion that I will be doing in small steps. My truck has a v8 in the 4wd position because it was originally a i6 truck. I have a 1972 c20 with a 292/465 that I am pulling all the parts off of. Besides the pivot ball I will need to get for my v8 what other parts can I not use off of the 292 truck? My truck also was born with a manual three speed so it already has the bracket on the frame for the z bar and clutch pedal assembly. I think the drive shaft from the c20 should I line up in my truck. Thanks guys
12-19-2020, 12:31 AM | #2 |
Re: Sm465 swap using parts out of a i6 truck?
Unless its a c30 frame i would start looking for a k truck frame
I went through this myself 3 dacades ago building my truck from a c10 to a k10 I chased down a few 4x4 partial truck frames then found a complete truck with a blown motor and a rougher cab I went and frame swaped it installed my motor and drove it right away C10 c20 trucks widen the frame at the back axle to accommodate coil springs C30 and k10 k20s are more straight frame rails over the rear axle Sm465 have a different output shafts for rwd and 4x4 trucks as well Your 200r4 will run better if you get proper gears closer to 3.73 |
12-19-2020, 12:39 AM | #3 |
Better to start with a complete chassis then piece everything together
Buy everything seperated will cost much more I picked up a 4x4 in carlsbad nm drove it home to the yukon used lots of oil but got it home have to look around craigslist and ebay and Facebook market place at nearby states and cities The other big thing is post up want adds as well looking for 67 to 72 4x4 trucks Last edited by gmc684x4; 12-19-2020 at 12:45 AM. |
12-19-2020, 12:52 AM | #4 | |
12-19-2020, 01:00 AM | #5 |
Here are a couple of rear frame pics
12-19-2020, 01:01 AM | #6 |
All about them K’s
I would highly recommend running a hydraulic clutch and ditching the factory mechanical linkage setup. If you’re interested I can answer any questions you’ve got. I love the hydraulic clutch in my K20.
Carlsbad to Yukon? I bet that was quite an adventure in a truck you just bought and didn’t know the history on haha.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-19-2020, 01:14 AM | #7 |
I fixed more things in his driveway that havent worked since the 70s lol
I learned from my 69 that came from arizona ask questions dam squiters didnt work sucked driving into seattle had to pull over clean the mud a few times off the winsheild I like a mechanical clutch setup almost never fails but you can gain header space with the right hydraulic setup i am on the search for a nv4500 for my k30 build depends if i can find an early one use Docs thread how to convert to old skool of it its 96 up switch to hydro clutch |
12-19-2020, 01:18 AM | #8 | |
12-19-2020, 01:21 AM | #9 |
4x4s and newer trucks do not use the bellhousing tranny mount they use a standard tranny mount like an auto
12-19-2020, 01:29 AM | #10 |
Well for the time being while the truck is still 2wd will I need the mount? I have a v8 three speed column shift bell housing crossmember that I can use as well. I’m not sure if these is a difference in the crossmembers or just the mounting location.
12-19-2020, 03:26 PM | #11 |
