Old 12-19-2020, 12:21 PM   #1
03BlkZ
Help with alternator
I am lost! I am restoring my 70 C10 with 350. I am installing an American Autowire Classic Update harness in the truck and the wiring is for a modern alternator with internal voltage regulator. I don't know what kind of alternator to buy. Please help! I would appreciate feedback from people that have used the same harness kit. Thanks!
03BlkZ is offline   Reply With Quote
Old 12-19-2020, 12:31 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Help with alternator
You mean a internal voltage regulator .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-19-2020, 12:36 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by 03BlkZ View Post
I am lost! I am restoring my 70 C10 with 350. I am installing an American Autowire Classic Update harness in the truck and the wiring is for a modern alternator with international voltage regulator. I don't know what kind of alternator to buy. Please help! I would appreciate feedback from people that have used the same harness kit. Thanks!
There are a lot of threads on the subject. Read through this one to see if it answers your questions. (check post #18)
http://67-72chevytrucks.com/vboard/s...d.php?t=803254
LockDoc
Leon
Old 12-19-2020, 12:51 PM   #4
03BlkZ
So it's looking like a 10 or 12 SI alternator should work.
Old 12-19-2020, 01:36 PM   #5
Wrenchbender Ret
You need to get one that is designated for a V-8 engine & mounting on the correct side that you have. They all have about the same mounting but they are clocked for the terms. to be in the best position.
George
Wrenchbender Ret is offline   Reply With Quote
Old 12-19-2020, 01:50 PM   #6
gmc684x4
It will be using 73 up c10 alternator in a 10 or 12 si configuration
If you want to step up from the si to a cs alternator nappa has a ec82 adapter plug kit with resistor
As for the cs 130 and 144 i am not sure which vehicle work with v belt setups both i have are from a 92 and a 99 trucks setup for serpentine belt
gmc684x4 is offline   Reply With Quote
Old 12-19-2020, 01:57 PM   #7
03BlkZ
Thank you! That's the info I needed. Looking at a 10 or 12 si.
Old 12-20-2020, 02:31 PM   #8
driller35
driller35's Avatar
Personally i went with the CS130 as was upgrading to efi as well and wanted the cleanest power supply heres what i used and also the link to the thread
Thanks Dave 12 for starting and Dmjlambert, VetteVet, Vince1, Gmachinz , enjoying everyones input and gave me the direction I want to do in my 1970 C10 CST alternator upgrade,
im gonna go with ACDelco 3351011 cs130 this already has vpulley mounted
ACDelco PT2145, hopefully resistor correct
now I am assuming this comes with a big enough resistor already in place, if someone knows for sure please chime in
http://67-72chevytrucks.com/vboard/s...d.php?t=763180 read the whole thread as lots of info in there
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD
70 Chev CST, 350 auto, PS, PB, AC, tach
driller35 is offline   Reply With Quote
Old 12-20-2020, 06:08 PM   #9
dmjlambert
dmjlambert's Avatar
I used the ACDelco PT2145 adapter for my CS144 alternator, and it appears to be enough resistance and works well. It is 510 ohms. I suspect it will work for you.
dmjlambert is offline   Reply With Quote
Old 12-05-2022, 12:47 PM   #10
MrWhoopee
MrWhoopee's Avatar
Rather than start a new thread, I'll add to this one. My '68 GMC K2500 is used almost exclusively as a snow plow and firewood truck. It has a 350 with 10si alternator. The alternator does not keep up during intensive plowing sessions. Lots of up and down, right and left with the plow, plus the extra lights, heater etc. runs the battery down enough that if you stall the engine it won't restart. I'm planning to upgrade to a 12si. I've read the other threads on alternator upgrades, but I'm having a little trouble determining what, if anything, I need to do besides the alternator itself. I'm also seeing 12si alternators (not genuine AC Delco) advertised with 140 amp output. Wondering if anyone has any experience with them.
TIA
MrWhoopee is offline   Reply With Quote
Old 12-07-2022, 04:50 PM   #11
HO455
Post Whore
HO455's Avatar
Here is some information on the electrical system that should help you with your decision.
http://www.madelectrical.com/electrical-tech.shtml
RIP Bob Parks.
Old 12-07-2022, 07:07 PM   #12
HO455
Post Whore
HO455's Avatar
TIA
The general consensus on the hot rodded SI alternators is that they will work but they have two short comings. One is the Chinese components used for the regulator. The second is heat failures. The cooling system for the alternator doesn't get upgraded and the units end up running too hot if they are putting out high amperage for extended periods. Running hot with substandard components isn't a good combination. Personally I would determine the amperage drawn you require and go 20% above that with a different factory alternator.
RIP Bob Parks.
Old 12-08-2022, 10:49 AM   #13
geunther
geunther's Avatar
I have installed Powermaster 10SI units in both my 72 and in an 81 CJ7. Both due to adding fuel injection and wanting more stable voltage. I have had good luck with both. The stock Jeep 37A Delco unit wouldn't even run my heater after putting a bigger heater motor in.
Also, I had to re-clock both of them, which is not hard to do.
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
