12-19-2020, 07:41 PM | #1 |
drive shaft length
ok so I have a 350 that I have most of the parts to build and I am going to put it in my truck in place of the 250 I6, for now I am retaining the Saginaw 3 speed trans but am eventually going to put a 4 speed behind it. figured I could save up to get a good transmission once the truck is on the road and later on I could put a gearvendors over/underdrive unit in the truck. my question though is when the 350 gets bolted into the truck will I need to increase the length of my driveshaft or does the 350 sit far enough back that its not an issue? any help would be greatly appreciated.
thanks |
12-20-2020, 09:08 PM | #2 |
Re: drive shaft length
Should be same location.
12-20-2020, 09:45 PM | #3 |
All about them K’s
I would leave the transmission in the original mounting spot and mount the 350 where it needed to go if that makes sense. I don’t play with two wheel drive trucks much, so I can’t tell you for sure which set of frame holes the engine crossmember would need to be in for it to work like this.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-21-2020, 05:00 PM | #4 |
Thanks guys, that should make things a bit easier for me
