12-20-2020, 11:17 AM | #1 |
Vent windows
need help with rebuild kits, who has the best kits, any experience with them. Just picked up some used ones ,thanks rippen,and would like to see if I can clean them up
My search doesn't work
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-20-2020, 11:35 AM | #2 |
Carpe manana
Re: Vent windows
Use the rubber from Precision https://www.prp.com/product/detail/1...ickup&type=All
These are a chore to rebuild imo. I’ve done three sets. The pivot rivet doesn’t need to be removed to rebuild unless you were going to rechrome the glass surrounds. On Nos rubbers water soluble lubricant helps to set them into the channel but the repro rubber is more deformable and you probably won’t need it though it wouldn’t hurt. Grind off the old rivets. You have more skills than I so maybe the OE style replacement rivets will work for you with the set tool provided. I made use of pop rivets like many others have done. Do one at a time using the other as a template for reassembly. Here’s one thread that might be useful: http://67-72chevytrucks.com/vboard/s...d.php?t=715546
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 12-20-2020 at 11:38 AM. Reason: Added |
12-20-2020, 02:04 PM | #3 | |
Re: Vent windows
We'll see how it goes, and post up results Thanks for the links, good read
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-20-2020 at 02:10 PM. |
