12-20-2020, 08:23 PM | #1 |
Frame question
Does anyone know if all the 67-72 half ton 2wd lwb frames are the same .....I am talking about the bare frame....I know there are different rear suspensions....thanks
1968 GMC stepside long bed 2004 GMC Yukon 2004 Chevy SSR 1969 Chevelle SS 1946 Chevy 4 door sedan 1923 C-Cab |
12-20-2020, 08:39 PM | #2 |
Re: Frame question
Yes
12-20-2020, 10:00 PM | #3 |
Re: Frame question
Basic frame is but there were some that had leaf springs instead of coils.They can be swapped around with a little fab work.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
12-20-2020, 10:52 PM | #4 |
Re: Frame question
67 frames have less clearance by the engine for headers.
The design of the exhaust hangers that are riveted to the frame changed a bit from year to year. I swapped the entire front suspension from a 72 onto a 69 frame once, and some of the crossmember bolt holes didn't quite line up. Had to do some drilling to make it work. There might be some differences from year to year where the power steering gearbox mounts. |
12-21-2020, 12:15 AM | #5 |
Active Member
Re: Frame question
Some frames have little cut outs, or bends, under the cab. Some frames don't.
12-21-2020, 01:38 AM | #6 |
Re: Frame question
On a leaf sprung rwd c20 you can add the coil spring upper brackets add the truck arm brackets to the rear subframe cross member and convert to coil springs
12-21-2020, 09:16 AM | #7 |
Re: Frame question
The early frames didn't have clearance for the P. S. gear box.
12-21-2020, 12:24 PM | #8 |
Re: Frame question
12-21-2020, 12:51 PM | #9 |
Re: Frame question
12-21-2020, 04:45 PM | #10 |
Re: Frame question
The holes through the radiator support brackets are smaller on 67-68, so the 69-72 support bushings don't fit.
