Old 12-23-2020, 11:37 AM   #1
dodge8mm
Rear end tag straightening
Morning all, looked around a bit and didn't see what I was looking for. I took the rear end tags of off my 1972 GMC C20. Has dana 60, with 4.10 limited slip. I cleaned the rust with CLR and a brush, the limited slip tag is crinkled, any way of flattening, straightening it without ruining the stamping on it?
dodge8mm is offline   Reply With Quote
Old 12-23-2020, 11:47 AM   #2
Greg58
Greg58's Avatar
Re: Rear end tag straightening
I would put it in a vice with 2 pieces of soft pine against the jaws.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 12-24-2020, 12:13 AM   #3
FirstOwner69
FirstOwner69's Avatar
I'd probably put it on a hard, solid flat surface (think the anvil portion of your vice or piece of 1/4" thick steel) with the raised lettering upward. Then take something like a piece of steel bar stock thin enough to place on edge between the lines of lettering and tap with a hammer. Even a wood paint stirrer may work.
Jim
FirstOwner69 is offline   Reply With Quote
