Old 12-23-2020, 03:09 PM   #1
RADustin
inner door glass felts
The felts that attach to the door panels, are they different for 73-76 vs 77+?
I have the full precision kits, but the U clip isn't deep enough to fully seat the felt on the door panel. They are 5/16-3/8" shallow, on both front and back doors. Before I hack up my beautiful door panels, I just want to ensure what is what.
I have a call in with precision, but it seems they are all out for the holidays- and ofcourse I'm looking to finish this up over the holidays.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 12-28-2020, 10:41 AM   #2
TKCR
TKCR's Avatar
Re: inner door glass felts
Did you find out anything?
I know what your talking about. I had a set also that was like that. I was restoring a set of panels for someone. The clips were small compared to the originals. I had to do some trimming, and had to make a few new holes, because the clips didn’t line up.
Now, the second set I got was perfectly fine. The clips were the right size and they all lined up with the door panel. So I’m guessing that the felts with the small clips are actually for another year of door panel. Both of these “were” supposed to be for the 81-87 door panel.
Old 12-28-2020, 11:04 AM   #3
TKCR
TKCR's Avatar
I did some checking myself at Precision. I looked up the parts separately, instead of the kits.
73-80 inners are WFL & WFR 10073
81-87 inners are WFL & WFR 10081
I have a guy that sells Precision seals from FB. He looked at the kits and confirmed that the inner sweeps were a different part number, which meant a different part. So it definitely seems to me, that when Precision put these kits together, wrong parts were put in the kit. The part numbers I posted above are the correct part number for the inner sweeps, if you were to purchase them separately. This is what I got for the next set of door panels that I am doing, and they are the longer clips, and they line up with the panel.
Hope this helps.
Old 12-28-2020, 05:37 PM   #4
RADustin
Hope this helps.
I still haven't got any answers from Precision. x-mas must have them all shut down, right when most of us are trying to get some stuff done.
I'll check those numbers vs what I have.
What I'm curious is if 73-76 is different than 77-80...since the door panels are different.
1949 Chevy 3100 P/U
Old 12-28-2020, 05:50 PM   #5
TKCR
TKCR's Avatar
When I looked at their website for this part, they went from 73-80, and then 81-87. That’s why I added the part numbers to the previous post. So from that, I would assume there is no difference from 73-76 to 77-80, since it’s calling for the same part number.
Old 12-28-2020, 05:58 PM   #6
TKCR
TKCR's Avatar
And looking at other vendors, they have them listed the same way.
73-80 and then 81-87.
Old 12-29-2020, 11:45 AM   #7
blazer2007
The other thing I heard of was the 81 up glass is thinner. Don,t know if that has anything to do with the felts
blazer2007 is offline   Reply With Quote
Old 12-29-2020, 04:41 PM   #8
RADustin
the parts I have are WFL/R 112077 (rear) and WFL/R 110073 (front)
1949 Chevy 3100 P/U
Old 12-29-2020, 04:42 PM   #9
RADustin
no this is a problem with the door panels.
I haven't installed yet to see how much trouble the glass will give me
1949 Chevy 3100 P/U
Old 12-30-2020, 11:55 AM   #10
RADustin
talked to Jeff at PRP.
Basically just need to trim the panels to make it work.
1949 Chevy 3100 P/U
Old 12-30-2020, 03:41 PM   #11
69Tom
69Tom's Avatar
I had to cut one door panel on my 74 when using Precision inners. I found a NOS GM inner felt for my passenger door panel, so I don't have to cut that one when I restore it.
69Tom is offline   Reply With Quote
Old 12-31-2020, 08:02 PM   #12
Pontiac1976
Pontiac1976's Avatar
GM had a two different style that changed back in the day I forget what year most of them are long gone (it the clips design) But if you have the right year inner window felts for the door panels your using you should be ok there. You have to pare the glass and the felts outer and inners door panels as the same year for best fit. But some time the door maybe tweaked so you may need to tweak felts or the door channel or the clips.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 12-31-2020, 08:41 PM   #13
Pontiac1976
TKCR first pic shown in this quote: is for sure 81-87 felts short and low clips.
